Please help - can't figure out how to stop insert record on form validation
Thread begun 9/01/2010 8:51 am by dan361748 | Last modified 9/01/2010 1:31 pm by Jason Byrnes | 2350 views | 3 replies |
dan361748
Hi - can't figure out what I am doing wrong.
Trying to stop duplicate records from being inserted into my table, using 'email' as the key.
I have set up my recordset to check the email, created the form have the validation show if behaviour showing the error if there is a duplicate record.
Even if the error shows, the insert record still puts the record in.
I have been trying using the Rules manager to create a rule that is success if $totalRows_usremails is null (I think?) but just can't seem to figure it out. I then set the insert record behaviour to trigger on Rule: Validation Success but either get header errors or it doesn't work.
Please help! My error messages work but the insert record ignores them!
you need to use the Server Validations part of CSS Form Buiilder.
Go to Insert -> Webassist -> CSS Form Builder -> Server Validations
Select number validation.
For the server variable enter:
$totalRows_RecordsetName
where RecordsetName is the name of your recordset.
Set the minimum to -1 and the max to 0
dan361748
Thanks Jason - I've done this but it still does not work.
I've removed all my 'validate show if' to make the code a little simpler. At this point, I just want the form to not insert a record if the validation fails, which I can't seem to do.
$totalRows_usremails is returning a value larger than 0, but the form still posts to the table. Can you help further?
ERROR_REPORTING(E_ALL);
ini_set("display_errors","ON");
<?php require_once('Connections/boomcms.php'); ?>
<?php require_once("WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_usremails = "-1";
if (isset($_POST['email'])) {
$colname_usremails = (get_magic_quotes_gpc()) ? $_POST['email'] : addslashes($_POST['email']);
mysql_select_db($database_boomcms, $boomcms);
$query_usremails = sprintf("SELECT * FROM newssubscribe WHERE email = %s", GetSQLValueString($colname_usremails, "text"));
$usremails = mysql_query($query_usremails, $boomcms) or die(mysql_error());
$row_usremails = mysql_fetch_assoc($usremails);
$totalRows_usremails = mysql_num_rows($usremails);
// WA Application Builder Insert
if ($_SERVER["REQUEST_METHOD"] == "POST") // Trigger
$WA_connection = $boomcms;
$WA_table = "newssubscribe";
$WA_sessionName = "newssubscribe_id";
$WA_redirectURL = "";
$WA_keepQueryString = false;
$WA_indexField = "newssubscribe_id";
$WA_fieldNamesStr = "firstname|lastname|email|postzip|subscribelive";
$WA_fieldValuesStr = "".((isset($_POST["firstname"]))?$_POST["firstname"]:"") ."" . "|" . "".((isset($_POST["lastname"]))?$_POST["lastname"]:"") ."" . "|" . "".((isset($_POST["email"]))?$_POST["email"]:"") ."" . "|" . "".trim(strtoupper(((isset($_POST["postzip"]))?$_POST["postzip"]:""))) ."" . "|" . "1";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|none,none,NULL";
$WA_connectionDB = $database_boomcms;
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id();
if ($WA_redirectURL != "") {
if ($_SERVER["REQUEST_METHOD"] == "POST") {
$WAFV_Redirect = "";
$_SESSION['WAVT_subscribe_393_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_usremails . "",-1,0,"",",.",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"subscribe_393");
thje problem is code order, the validation is happening after the record inserts.
change:
$WA_fieldNamesStr = "firstname|lastname|email|postzip|subscribeliv e";
$WA_columnTypesStr = "',none,''|',none,''|',none,''|',none,''|none,none ,NULL";
if (!
if (
if (
if (
$WAFV_Errors = "";
if (
PostResult($WAFV_Redirect,$WAFV_Errors,"subscribe_ 393");
if (
$WAFV_Errors = "";
if (
if (!
if (
if (
so that the validation will occur before inserting the form
