Updated Confirm page in PS3 blank
Thread begun 9/01/2010 6:48 am by wrigd | Last modified 9/08/2010 11:35 am by Jason Byrnes | 7914 views | 15 replies |
wrigd
I have downloaded the 'Known Issues' update regarding the Product Options are not displaying in the email receipt's or admin section. I have uploaded the updated contained files to my PS3 store. However when I test the store everything seems to work fine until it gets to the confirm.php page. On this page I just end up with a blank page. I wonder if you are able to help me or give me an idea as to why this might be happening? Many thanks.
when a page displays blank, it means a php error is occurring.
Add the following at line 1 to turn error reporting on:
error_reporting
(E_ALL);
wrigd
Hi, thanks for the quick response.
The error that is showing is regarding a missing 'wa_evaluate.php' file in both confirm.php and pp_confirm.php but I do not have a wa_evaluate.php file present. This is not in my Powerstore 3 folder. Thanks again for your help.
You can download the wa_evaluate file from the power gallery download page. it is included in the Database Integration update.
wrigd
Hi, I don't have Power Gallery. Is there any other way I can get this file? Thanks.
here you go.
wrigd
Many thanks for that. I am now receiving an error on teh pp_confirm.php page which says, 'You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '@emailaddress.com,0)' at line 1.
Thanks.
This error indicates that you are trying to store the email address in a column that is numeric.
check the ecart store order summary and store order details server behaviors to see where you are storing the email address. That column will need to be changed to a varchar column, the data type in the server behavior will need to changed to text as well.
wrigd
I am now receiving a whole new error on the pp_confirm.php page which states:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /filepath/wa_evaluate.php:1) in /filepath/WA_eCart/WA_eCart_Definition_PHP.php on line 480
I seem to be finding that this solution is not so easy to install, for me anyway.
Many thanks again with all your help.
hmm, seems the wa_evaluate fle I sent to you has a syntax error in it, my apologies.
in the wa_evaluate file, line 1 has a number of blank spaces before the opening php tag:
" <?php"
remove those blank spaces:
"<?php"
