frame in a frame
Thread began 9/01/2010 6:23 am by Cologne | Last modified 9/02/2010 7:32 am by Ray Borduin | 1308 views | 3 replies |
Cologne
frame in a frame
hi, i wonder if i can use a frame in a frame. I got a page with framework inside. Can i put this page with framework into an other?
Does framework check if the code allready exists. On my testsite i go two time the meta http-equiv line in the code.
Cheers,
Denis
We didn't specifically test that scenario, so it is possible there could be issues. If you have an example we can look at we might be able to suggest a way to correct problems you run into.
Cologne
Hi Ray,
this is a test page (www.denis-online.de/], I put the gallery with framwworks, and if you look the code the line
is two times in the page, it works, but it doesnt look cool :-)
Denis
There are a couple of potential solutions to this issue.
1) you could remove the meta tag from one or both of the plugins you are using and have it on the page itself.
2) you could remove the ->Header reference for the plugins and instead add the meta data, script, and css individually using bindings.
Do either of these solutions work for you? Without seeing the exact structure of the plugins you are using it is difficult to suggest which method I would actually use.
