Only the first address displays
Thread begun 9/01/2010 6:13 am by nobikerwave414074 | Last modified 10/20/2010 5:55 am by mallardnj111947 | 2891 views | 6 replies |
nobikerwave414074
I am pulling my addresses from a database. Setup was smooth, but when I run the page the only result that displays on the map is the 1st record in the table.
In the Wizard, did you select the Show Multiple option?
can you post a link where I can your page top examine the code.
nobikerwave414074
Show Multiple Checkbox is greyed out - Unable to select
Whe setting up map the "Show multiple" and "From" options are not allowing me to select
nobikerwave414074
Link to map
index2.cfm
nobikerwave414074
Help
index2.cfm
mallardnj111947
I had the same problem, and it seemed to be related to having a custom recordset on the page (ASP VVBScript) with parameters. Basically I created a generic SELECT * query, then added the map, then customized the query with parameters, etc. that worked for me.
