CSS Form Builder 2 Build GMC3
Thread begun 8/31/2010 2:26 pm by Anna Robinson | Last modified 9/13/2010 10:33 am by Justin Hood | 5257 views | 16 replies |
Anna Robinson
You can download Build GMC3 at CSSFormBuilder_GMC3.zip
Engineering fixed the following 3 bugs in this build. QA is not complete yet.
- File Upload settings 'If file exists' Action selection is not being retained when set within the Form Builder Wizard.
- CSS and some includes left out when inserting a CSS form inside a template's editable region.
- Editing an existing form's design causes a second instance of the Server Validations server behavior to be added to the page.
We are currently planning to keep the beta open for approximately two more weeks. We appreciate all feedback!
anonymous
So far, everything that I have tested is working ok. I need to do a couple of more tests on another site to really be certain.
One issue though I have noticed since installing these betas (Form Builder and Dynamic Connections), under the WebAssist menu in Dreamweaver, I get the item "Get More Extensions" repeated twice so I have three of them. Minor bug and I'm not completely sure it is tied to these betas but only noticed it since installing the betas.
Brian
Anna Robinson
We'll look into it. Thanks for reporting!
Anna Robinson
Brian, We can't reproduce this. We tried a combination of products and haven't seen it. Can you tell me what you have installed in the last few months?
anonymous
Anna,
I had a weird issue where I the menu items for Framework Builder became not selectable. So, I reinstalled Framework Builder and now there is only one instance of Get More Extensions from the main menu. There is, though, an instance on the Framework Builder flyout as well.
Best regards,
Brian
anonymous
An issue I keep running into now that I have installed the new Form Builder is that I cannot get HTML Editor to work correctly.
It constantly tells me that the "Toolbar set "Custom" doesn't exist." and won't load the editor.
I also noticed that it was not creating the xml file for the custom the editor; only the js file was created in the custom folder.
Brian
Justin HoodWebAssist
Originally Said By: SOJO web
Brian
Hey, Brian. Thank you for reporting this.
Does this occur with editors that you're inserting with the Form Builder Wizard? Or does this occur when you're applying through HTML Editor's interface to a text area on your current page?
anonymous
Justin,
This particular instance is when using the HTML Editor interface. The only time I applied it through Form Builder, I didn't customize the toolbar so I am not sure if that would create the same problem.
Thanks,
Brian
  Justin,
Thanks,
Brian
Brian,
I've tried numerous times to get the error message you mentioned to appear by inserting a new form with the Form Builder Wizard and then editing the applied HTML Editor as well have with direct inserts with HTML Editor itself. I haven't had any luck. Do you have other extensions installed with this beta build? Are there more detailed steps you can provide?
anonymous
Justin,
I get the issue when I try to customize the toolbar and save it as a preset. The editor works fine if using one of the default toolbar settings. But, when I go in and make changes, it technically should write a new XML file as well and reference that file for the toolbar settings.
Now, I do have all of the WA extensions installed. So, I may go back and explicitly uninstall both Form Builder and HTML Editor and reinstall to see if that will help.
Best regards,
Brian
