ecart checkout with authorize.net
Thread begun 8/30/2010 4:51 pm by georgevargasa302189 | Last modified 8/31/2010 11:21 am by Jason Byrnes | 2882 views | 5 replies |
georgevargasa302189
I first tried to select remote processing with the checkout wizard and I just get an error message 103 from authorize.net. I called authorize.net support and they indicate that I should be using AIM with a shopping cart.
I change to AIM, and now when I press the Submit Order button on the Confirm page, I just get a blank web page. It still indicates it is on the confirm page in the Web address, and it says done at the bottom.
Any ideas?
a blank page means there is a php error occurring but error reporting is turned off.
add this code at line 1 of the page to turn error reporting on:
error_reporting
(E_ALL);
once we know the error we can give more information.
georgevargasa302189
Here is the message
Fatal error: Call to undefined function curl_init() in C:\Inetpub\wwwroot\UltraAirVent\WA_eCart\Adv_CO_Scripts\AuthNet_PHP.php on line 42
this error means that the curl library is not enabled in your php.ini file.
you will need to edit the php.ini file.
Find the following line in the php.ini file:
;extension=php_curl.dll
and change it to:
then restart IIS.
georgevargasa302189
Thank you very much, it worked great!!!
glad to hear it is working.
