Redirect to Prouduct Detail Page after login
Thread begun 8/29/2010 7:21 pm by siteontime | Last modified 8/30/2010 2:22 pm by Jason Byrnes | 2767 views | 3 replies |
siteontimeBeta Tester
I am adding a wishlist to the powerstore and have everything working except for the redirect. The user has to be logged in to add to the wishlist.
Here is the page URL that comes up on redirect from a successful login:
Products_Detail_new.php?accesscheck=%2FProducts_Detail_new.php
How do I change this to redirect to the correct Product Detail page.
what is the correct product detail page name?
can you give some details on what is wrong with the redirect.
The Products_Detail_new.php is listed twice in the url as you can see in the post above and it is not including the ProductID variable. So when it redirects it says no product found.
Hope that helps. Thanks for such a quick reply.
the second listing of the details page in the URL is needed for the redirect to occur.
Security assist uses the access check querystring variable to know what the previous page was.
to get the product id in the querystring as well, you will need to edit the restrict access code.
edit the redirect:
WA_Auth_RestrictAccess("Products_Detail_new.php");
to capture the product ID querystring. for example, if the querystring is named productID:
Products_Detail_new.php?productID=53
edit the redirect code to:
WA_Auth_RestrictAccess("Products_Detail_new.php?productID".echo(isset($_GET['prodID'])?$_GET['prodID']:"")."");
