Quantity discount based on items in single category
Thread begun 8/29/2010 6:23 pm by hmyrick308645 | Last modified 9/02/2010 6:30 am by Jason Byrnes | 2262 views | 3 replies |
hmyrick308645
I need to offer a quantity discount for items in a single category. I added a "Category" column to the cart. Then I went to bind the category to the new column.
The problem comes in when I attempt to retrieve the item category by modifying the products recordset (or creating a separate recordset to retrieve the category). Because some of the items are in more than one category, I get all the item's categories, not just the discount category.
Is there a way to solve this?
where the products belong to multiple categories, it is going to problematic to set the discount based on the category.
a simpler approach would be to mark the items as discounted directly in the products table.
you will need to create a discounted column in the products table and set it to 0 for items that should not be discounted and 1 for items that should be discounted.
use this column in the add to cart button instead.
hmyrick308645
says. apilber
Thanks Jason. That worked well.
Great, glad to hear you have it working.
