cart in ssl not redirecting to checkout.php
Thread begun 8/29/2010 6:07 pm by watercolor346374 | Last modified 8/30/2010 11:54 am by Jason Byrnes | 7484 views | 12 replies |
watercolor346374
Hello,
Well it was working then I uploaded a revised version of the cart, recoded for the ssl and now when I click on check out, I go into the ssl and I get the page that says your cart is empty. It does not go to my checkout.php page. Here is what is in my browser:
cart.php instead of :
checkout.php
I am not sure if I left something out in the code, so I have included my cart.php page. I need to get this site up and running by Monday night...I would appreciate heip.
Thank you,
K
If you would like to see what happens you can go to:
index.php
site is in a test file.
the problem is that you are changing domains.
See the "Applying SSL to your eCart checkout" tutorial on the eCart support page:
ecart/
watercolor346374
ssl
It worked when I originally set it up, then I changed the cart and reuploaded it. The ssl cert is under kshotz.com. I should be able to use this for other domains under kshotz.com. That is what I was told by Host Gator. I did read the article, I have ecart 4 so I read the one titled SSL and ecart sites. From the looks of it I would have to redo my checkout page. Is this so? Then I am wondering why it previously worked when I set the redirect to the https.
When I go into my ssl files I do see the files for my test site and I have been uploading new cart and checkout and confirm to it as I upload to my http site. Still stumped as to why it worked before and not now.
K
the issue is that you are changing domains when going to the ssl server.
you have the normal pages at:
index.php
and the ssl page at:
cart.php
the first is using the domain:
www.karenshotz.com
the second is using a different domain:
www.kshotz.com/
the tutorial i linked to previously will walk you through the procedure of passing the cart contents to the ssl domain.
watercolor346374
ssl
Karenshotz.com is under the domain of kshotz.com karenshotz.com is a sub domain of kshotz.com. I was told that should not make a difference using the ssl. so the redirect to the ssl would be the path: checkout.php, wouldn't it? I did the tut for ecart4 re setting up an ssl. When I was doing the checkout page, none was made, my old one still existed. Is this a problem? I uploaded the cart, checkout, confirm and wacart pages to my http and https and I still get:
cart.php in my browser...no passing to checkout.php
Thank you,
K
it does make a difference with sessions.
the issue is this:
The browsing session creates a cookie on the client computer with n ID.
Cookies are domain based.
As far as a cookie is concerned, the address:
www.karenshotz.com
and:
www.kshotz.com/
are 2 different domains. It does not matter how you register them, they are still 2 differant domains.
even the addresses:
www.karenshotz.com
and
karenshotz.com
would be considered 2 different domains by the session cookie.
when you have 2 different domains, you need to pass the session information from one to the other.
the tutorial I linked to originally has instructions on how to accomplish this.
watercolor346374
ssl
Do I have to have ecart5? I have ecart4.
watercolor346374
ssl
Thank you, Jason. I am getting through now. Only one item is not being passed and that is my promo code discount. How would I put the code into the checkout.php page where the rest of the variables are beign passed?
<tr>
<td class="eC_SummaryLabel">WWMAG 20%</td>
<td>-<?php echo WA_eCart_DisplayMoney($winkee, $winkee->GetDiscounts()); ?></td>
</tr>
Also has a session:
if((((isset($_POST["txtpromocode"]))?$_POST["txtpromocode"]:"") != "")) {
$_SESSION["promocode"] = "".((isset($_POST["txtpromocode"]))?$_POST["txtpromocode"]:"") ."";
Thank you,
K
in the hidden form that is created on the cart page, create a new hidden form element:
<input type="hidden" name="txtpromocode" value="</php echo(isset($_SESSION["promocode"])?$_SESSION["promocode"]:""); ?>" />
watercolor346374
ssl
Hi Jason,
I put the hidden field in the cart page...discount does not pass to the confirm. do I need to add any thing to the checkout page?
Thank you,
K
