ecart5 thumbnails to display
Thread begun 8/29/2010 3:45 pm by gpaul | Last modified 8/31/2010 9:12 am by Jason Byrnes | 2887 views | 5 replies |
gpaul
I've read the tutorials and most of the questions here in the forum, but I still cant seem to get my images (thumbnails) to display in the cart. I thought I had the proper binding.
Here is the code for the image:
class="eC_GroupColumn"><a href="images_Detail.php?<?php echo $jfincart->DisplayInfo("ID"); ?>=<?php echo $jfincart->DisplayInfo("Thumbnail"); ?>"><img src="images/<?php echo $row_WADAimages["image_file"]; ?>" alt="<?php echo $row_WADAimages["caption"]; ?>" class="eC_ProductThumb" /></a>
This is the code for the bindings:
if (!$jfincart->IsEmpty()){
$cart = $jfincart;
$ATC_itemID = "".($row_WADAimages["image_id"]) ."";
$ATC_AddIfIn = 2;
$ATC_RedirectAfter = "";
$ATC_RedirectIfIn = "";
$ATC_itemName = "".($row_WADAimages["caption"]) ."";// column binding
$ATC_itemDescription = "".($row_WADAimages["description"]) ."";// column binding
$ATC_itemThumbnail = "".($row_WADAimages["image_file"]) ."|";// column binding
$ATC_itemWeight = floatval("0");// column binding
$ATC_itemQuantity = floatval("".$_POST["jfincart_1_Quantity_Add"] ."");// column binding
$ATC_itemPrice = floatval("0");// column binding
$ATC_itemQuantity = floatval($ATC_itemQuantity);
if (is_numeric($ATC_itemQuantity) && $ATC_itemQuantity != 0) {
$cart->AddToCart($ATC_AddIfIn, $ATC_RedirectIfIn, $ATC_itemID, $ATC_itemName, $ATC_itemDescription, $ATC_itemThumbnail, $ATC_itemWeight, $ATC_itemQuantity, $ATC_itemPrice);
if ($ATC_RedirectAfter != "" && $cart->redirStr == "") {
$cart->redirStr = $ATC_RedirectAfter;
if (isset($_SERVER['QUERY_STRING']) && $_SERVER['QUERY_STRING'] != "") {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF']."?".$_SERVER['QUERY_STRING'];
else {
$_SESSION['WAEC_ContinueRedirect'] = $_SERVER['PHP_SELF'];
Can anyone direct me to solving this?
Thank you.
Gary
in the image code:
you are using the image file field from the recordset.
On the bindings panel, use the Thumbnail column form the cart object binding group instead
gpaul
Jason
Thanks for your reply, however I have not been successful.
First I changed
to
<img src="images/<?php echo $row_WADAimages["Thumbnail"]; ?>
Then I deleted all between the <td> tags and inserted the Thumbnail Binding
I also tried
<a href="images_Detail.php?=<?php echo $jfincart->DisplayInfo("Thumbnail"); ?>"> alt="<?php echo $row_WADAimages["caption"]; ?>" class="eC_ProductThumb" /></a>
And probably a few others.
Could you be more specific about how to fix this?
Again, Thank you for your help.
Gary
your source should use the eCart binding:
<img src="images/<?php echo $jfincart->DisplayInfo("Thumbnail"); ?>" />
gpaul
Jason
Thank you for your help, however it is not working and I have to think there is more going on.
First, I am also not getting the Description to appear, so it appears that the information is not getting called from the DB.
Second, I have an error symbol on the record set, when I open the RS dialog box, I get the following error message.
Paramimage is an invalid variable name; it does not appear in the SQL
Missing type for variable:Paramimage
ParamSessionimage is an invalid variable name; it does not appear in the SQL
Missing type for variable:ParamSessionimage
Missing Run-Time Value for variable:Paramimage_id
Missing Run-Time Value for variable:Paramimage_id2
Missing Run-Time Value for variable:ParamSessionimage_id
This is the code for the Thumbnail as I have it now:
<td class="eC_GroupColumn"><a href="<?php echo $jfincart->DisplayInfo("ID"); ?>"img class="eC_ProductThumb" width="150px" height="150px" src="images/<?php echo $jfincart->DisplayInfo ("Thumbnail"); ?>" alt="<?php echo $row_WADAimages["caption"]; ?>" /></a></td>
Again, thank you for your help.
Gary
the errors are the cause of the problem.
The error are saying that there are parameters created for the recordset but they are not being used, do not have data types, or runtime values.
if you do not need these parameters in the recordset, then you should delete them
