power cms not functioning well after server change
Thread began 8/28/2010 11:07 am by deb364196 | Last modified 8/30/2010 9:50 am by Jason Byrnes | 758 views | 1 replies |
deb364196
My site was changed to an alternative server.... the website url is: www.cougarshockey.ca
Now....can't upload images or files (ie pdfs) - says they've been uploaded successfully, however they're not there
Under the "settings" tab it says that the "uploaded image folder" is:
/var/www/vhosts/cougarshockey.ca/httpdocs/2010/powercms///files
When I go to "insert an image" and I choose to browse the SERVER for that image.....I get the following error:
There are errors in your configuration or server. If the messages below describe missing variables, please check the supplied configuration.php.dist for notes on their usage.
KFM does not work if you have safe_mode enabled. This is not a bug - please see PHP.net's safe_mode page for details
Please advise keeping in mind that I am not as technically advanced as some of the other users in your forum.....;) but I need help on this.
Thx in advance,
deb
you will need to change the path for the uploaded images location.
This path will be different from server to server.
you should be able to contact your host to get the server path to the root of your sites httpdocs folder, and replace what is in the settings with the path your host provides.
