Changing the date format of a field in a results page
Thread begun 8/28/2010 9:44 am by iainmacdonald331081 | Last modified 8/29/2010 12:12 am by John Langer | 2507 views | 3 replies |
iainmacdonald331081
This must be possible - I'm just trying to change the date format on a page here to the format 28th August 2010, but not sure how to go about it.
educational-tours.php
I've done it OK on the details page :
tourdetails.php?packageID=155
Using
$colname_DateFormat
= "1";
if (isset(
$_GET['packageID'])) {
$colname_DateFormat = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
mysql_select_db($database_connPackages, $connPackages);
$query_DateFormat = sprintf("SELECT date_format(dateadded, '%%D %%b %%Y') as formatted_date FROM packages WHERE packageID = %s", $colname_DateFormat);
$DateFormat = mysql_query($query_DateFormat, $connPackages) or die(mysql_error());
$row_DateFormat = mysql_fetch_assoc($DateFormat);
$totalRows_DateFormat = mysql_num_rows($DateFormat);
Any pointers on how to do the same on the results page would be much appreciated.
John LangerBeta Tester
Where you want to display the date just use this code changing your recordset name as appropriate
<?php echo date('j F Y',strtotime($row_YOUR_RECORDSET_NAME['your_date_field'])); ?>
iainmacdonald331081
Thanks John - I now have no idea why, when I looked at how to do this a good while ago, I found the convoluted method used above in the details page.
I'm sure at the time, it looked like one of those little things which had far more complicated a solution than ever seemed reasonable.
So I really appreciate finally discovering that there is, after all, a straightforward way of doing this!
No problem Iain, glad it worked <phew> :)
