ecart 5 confirm page incomplete
Thread begun 8/27/2010 3:04 pm by georgevargasa302189 | Last modified 8/30/2010 1:06 pm by Jason Byrnes | 3134 views | 5 replies |
georgevargasa302189
I upgraded to ecart 5 and recreated my site in php to get around a problem I was having with a confirm.asp page in ecart 4.
Now I get a confirm page but it does not contain the checkout buttons at the bottom of the page. Instead there is a time stamp message.
<input type="hidden" name="x_fp_timestamp" id="x_fp_timestamp" value="
I am including a screen shot, and the actual confirm.php file
most likely a php error is occurring.
add the following to line 1 of the conform page to see the error:
error_reporting
(E_ALL);
georgevargasa302189
Here is the resulting message
Fatal error: Call to undefined function mhash() in C:\Inetpub\wwwroot\UltraAirVent\WA_eCart\checkoutScripts\WA_simlib.php on line 30
sounds like you php does not have the mhash library enabled.
try changing the WA_eCart/checkoutScripts/WA_simlib.php file to use the hash function instead.
change:
return (bin2hex (mhash(MHASH_MD5, $data, $key)));
return (bin2hex (hash(MHASH_MD5, $data, $key)));
georgevargasa302189
Thank you that worked.
Do you recommend upgrading to a newer version of PHP or would that possibly make it incompatible with my version of MySQL.
I have my local server working on IIS instead of MAXAMP.
I did this because I still need to use IIS for development.
I found a great article on how to do this called Installing PHP 5.2.3, MySql 5.0, IIS 6.0 on Windows XP install_php_mysql_iis.html
This works perfectly but I am worried about changing things since it works.
no, you dont need to upgrade, changing that one line should be all you need to do.
