Relationship between two tables
Thread begun 8/26/2010 2:53 pm by Vinicios Nussemeyer | Last modified 8/27/2010 11:39 am by Jason Byrnes | 2746 views | 5 replies |
Vinicios Nussemeyer
I have a project with the following characteristics:
Mysql tables:
Table customers (cliente_id, name, email address)
Table processes (process_ID, processo_numero, Arquiquo)
Table clientes_produtos (produtos_produto_id, clientes_cliente_id)
The relationship between the tables is OK: insert page register successfully process data in the table and writes the process ID of the client relationship on the table without problems.
Page processos_results:
This page lists all the cases registered in mysql. The recordset process was created automatically with the DataAssist. I show the fields processo_numero and file to download, no problems. The customer need not enter into search forms for listing the processes as they are filtered by customer ID (variable section) and I have done tests and it worked.
ISSUE:
My problem is in showing a field with the NAME of the customer linked to the process in the RESULTS page.
What I have done to try to solve:
1. I created a RECORDSET_CLIENTES to display just the client (name) linked to the process.
2. I tried to follow the tutorial post "Display data from related tables in results" in the forum but had no success. I created the second Recordset (RECORDSET_CLIENTES). But it really did not understand the steps to create a form variable and then move the second Recordset (RECORDSET_CLIENTES) into the loop.
HELP:
1. Please I need help on this issue. I think the tutorial post which I refer is incomplete because it ends without solution
2. Where can I find a complete tutorial and well-documented and preferably with the screens. The DataAssist has many tutorials and what I found was a tutorial file giving a perfect explanation for how the relationship between the tables but does not show how SHOW (results), edit or delete related data between them.
Thanks,
Vinicios Nussemeyer
you need to use a join query to display the related data.
See the following site for details on joined queries:
sql_join.asp
if you need help creating the syntax for the join query, a tool like Navicat is a great addition:
mysql_overview.html
it has a visual interface for creating complex queries.
Vinicios Nussemeyer
Thanks Jason,
but I wonder if the WebAssist has some tutorial to their customers as display data that are related to the three tables. As I said before: the tool "Relational Table Manager" works well for entering data in the table of relation between the two. But I need some guidance on how to do this with DataAssist because I am not PHP programmer but a designer and use the tools of WebAssist to streamline my development process and offer solutions better and better for my clients.
Thanks,
Vinicios
data assist doesn't have a way of showing the related data. you have to create the joined query to accomplish this.
The navicat tool I linked to before will help you in creating the query if you do not know how to create it yourself.
Vinicios Nussemeyer
Thanks Jason,
I'm downloading the trial version of Navicat. I will make the process of displaying the data it then.
Thank you for listening.
Vinicios
you're welcome.
