prebuilt email templates displaying too much posted label data
Thread begun 8/26/2010 11:58 am by johnb | Last modified 8/30/2010 8:05 am by Jason Byrnes | 2380 views | 4 replies |
johnb
How can I edit the code so that the prebuilt templates don't send everything posted to the label in the email? I have form with a huge tower of bindings and I really don't wanna have to put them in by hand. I just want to remove the label and header data from the array.
Right now each field is sending this:
"Contact Label Contact Header Office Telephone Number:"
I just want the "Office Telephone Number:" portion.
Thanks for any assistance on this.
In the template the code to write the label looks like:
<?php echo(str_replace("_"," ",$pkey)); ?>:</th>
you can use the replace function to remove part of the form name from the label.
<?php echo(str_replace("_"," ",str_replace("Contact_Label_Contact_Header """$pkey))); ?>:</th>
johnb
I did exactly as you said and it didn't work for me. Also, there are additional strings of text that need to be removed from the same template such as:
• General Info Label General Info Header
• About Label About Header
• More Details Label More Detail Header
• Branding Label Branding Header
• Media Label Media Header
• Practice Goals Labe Practice Goals
• HiddenFields fields:
johnb
I think I figured it out. It lookes like removing the space after "Contact_Label_Contact_Header " was the culprit? Not sure, but it worked when I pulled it out.
Also here is how I added all the rest of them. There is probably an easier way to accomplish this but I am just learning so this just made sense. If anyone would like to send a simpler solution I would be interested in knowing it.
<?php echo(str_replace("_"," ",str_replace("Contact_Label_Contact_Header""",str_replace("General_Info_Label_General_Info_Header""",str_replace("About_Label_About_Header""",str_replace("More_Details_Label_More_Detail_Header""",str_replace("Branding_Label_Branding_Header""",str_replace("Media_Label_Media_Header""",str_replace("Practice_Goals_Labe_Practice_Goals""",str_replace("HiddenFields_fields"""$pkey)))))))))); ?>:</th>
yes, that is the correct way for adding the additional labels to remove.
