Cannot modify header
Thread begun 8/25/2010 1:01 pm by Badger | Last modified 8/26/2010 6:58 am by Jason Byrnes | 2542 views | 5 replies |
Badger
I'm getting the old header error message:
Warning: Cannot modify header information - headers already sent by (output started at /www/visp/hollywo1/chandeliergroup.com/visitors_Profile.php:106) in /www/visp/hollywo1/chandeliergroup.com/WA_SecurityAssist/Helper_PHP.php on line 67
BUT
Only when trying to go from a registration page to a profile page
IE it's not the PHP gap problem.
I can get both pages working without the error if I remove SA from the profile page but them the username and password (IE the records) are not passed on
Any ideas
the headers already sent error is always caused by some sort of output to the page.
the error is reporting the issue at line 106 of the visitors_Profile.php page.
if you cannot spot the problem, send a copy of your page.
Badger
That's what I thought but line 106 looks like this:
<!-- InstanceEndEditable -->
File attached
the problem is lines 202 - 206:
if (!WA_Auth_RulePasses("Logged in to visitors")){
WA_Auth_RestrictAccess("visitors_LogIn.php");
this is trying to redirect to the visitors_LogIn.php but it is inside the head of the page, it needs to be moved to be before the doctype tag.
Badger
That's it. Thanks Jason
Just leaves an issue where I'm not to be able to go from the registration page to the profile page without having to enter the username and password.
Is it simply a question of adding the session details to the end of the link to the profile page?. If so could you show me what that might look like.
You would need to add a security assist Authenticate user behavior to the registration page.
The registration form only adds the user information to the database. once its added, you can perform the login.
