Menu Writer Home Button Missing
Thread begun 8/25/2010 11:20 am by marketing411053 | Last modified 8/30/2010 8:53 am by Jason Byrnes | 3050 views | 5 replies |
marketing411053
I made an adjustment to my menu and when I updated the files the home button is missing from all of the content pages now. Does anyone know how to get it back? I don't know what I did to change it. I was trying to adjust the width of the buttons to prevent overlap. This is fixed but now the content pages are showing the same menu that the home page does.
is this in a site sculptor site?
can you provide a link?
you could manually add it back to the menu.php file.
send a copy of the menu.php file and I can give you the code to add it back.
marketing411053
Thank you for your help. I am new to php and still struggle with one fix breaks something else. Here is a link to the site www.bat4ph.com -any button you go to after the index page does not have the home button in the menu bar. This is a site sculptor site with menu writer buttons. Attached is the menu.php code from CSMW_CONTENT.
change:
<ul class="level-0" id="cssmw_content">
<li class="parent"><span><a href="<?php echo($assumedRoot); ?>contacts0.php">Contacts</a></span>
<li class="parent"><span><a href="<?php echo($assumedRoot); ?>index.php">Home</a></span>
marketing411053
Menu Writer Home Button Missing Fix
THANK YOU so much! All fixed. Thank you Thank You Thank You!!!!!!!!!!!!!!!!!
you're welcome.
