Menu Writer doesn't work in Safari.
Thread begun 8/24/2010 10:27 pm by shelleymcneil360831 | Last modified 8/26/2010 1:30 pm by Jason Byrnes | 3597 views | 7 replies |
shelleymcneil360831
For some reason menu writer does not work in Safari.
CSS Menu Writer is web standards compliant and compatible with all modern browsers, as well as Internet Explorer 6.
What version of safari are you using?
please post link where i can see the problem to investigate the cause.
shelleymcneil360831
Menu not functioning in Safari or opera
Only some of the pages will open in Safari or opera but internet explorer works perfectly.
index.html
I am not experiencing an issue with your menu. I am testing in safari on both Windows and Macintosh and all menu items are functioning properly for me, I am not able to reproduce a problem.
shelleymcneil360831
wow you mean I spent the past 18 hours and going to bed at 5am for no reason
Thanks for your help....My client and I both cannot display all of the pages without manually typing in the html page. Any suggestions. I am using Safari on my pc.
I tried on another computer to reproduce the issue in safari, and still cannot.
The only guess i can come up with is the text-align property you have added to the a:active class in the main.css file.
a:active {
color:#FFFFFF;
text-align:center;
try changing that to:
a:active {
color:#FFFFFF;
/*text-align:center;*/
shelleymcneil360831
That worked
I have spent so much time on this...and have made myself insane over this. I cannot believe this little change that you recommended solved my problem.
Thank you Thank you Thank you.
great, glad to hear it is working.
