Red captcha
In one example I saw a that the captcha images were available in red instead of black, how do I apply the red? Is this a style?
Go to Edit the form design.
In the first drop down menu select Form elements. in the next dropdown select captcha, here you can change any of the captcha settings including color.
COuld not find any place to edit the captcha, Pleas tell me at what point in the wizard I find the drop downs you mentioned. When I found Captcha the only choice was "Standard"
Nick
On the fisrt page of the wizard, where you select The Form Contents and Design, Click the edit button next to form design.
In the form design Editor, select Form Elements, the captcha. This will bring you to the page where you modify the captcha settings.
