Using DataAssist Search Shows all records
Thread begun 8/24/2010 6:26 am by JBWebWorks | Last modified 8/25/2010 10:58 am by Jason Byrnes | 6120 views | 12 replies |
JBWebWorks
When i access the results page directly or when i click the submit button on the search page without any search input, the results page shows all records and i want it to show none.
Using this in the code
$WADbSearch1_DefaultWhere = "0<>0";
produces this error
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '0<>0 ORDER BY unclassified.ad_post_date DESC' at line 1
thanks for your help,
Jim Balthrop
for mySQL the correct default where syntax is 0 != 0
$WADbSearch1_DefaultWhere = "0 != 0";
JBWebWorks
Thanks Jason
tried that
and still got error message?
please post the exact error message and a copy of your page.
JBWebWorks
Error Message----
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '0 != 0 ORDER BY unclassified.ad_post_date DESC' at line 1
Page Code----
<?php require_once('Connections/connauto.php'); ?>
<?php require_once('Connections/connauto.php');?>
<?php require_once( "WA_SecurityAssist/Helper_PHP.php" ); ?>
if(isset($_POST["login1"])){
$WA_Auth_Parameter = array(
"connection" => $connauto,
"database" => $database_connauto,
"tableName" => "client_info",
"columns" => explode($WA_Auth_Separator,"client_email".$WA_Auth_Separator."client_pw".$WA_Auth_Separator."client_verified"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["user_name"]))?$_POST["user_name"]:"") ."".$WA_Auth_Separator."".((isset($_POST["password"]))?$_POST["password"]:"") ."".$WA_Auth_Separator."yes"),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"client_ID"),
"sessionNames" => explode($WA_Auth_Separator,"client_ID"),
"successRedirect" => "my_account1.php",
"failRedirect" => "?failed=true",
"gotoPreviousURL" => TRUE,
"keepQueryString" => TRUE
WA_AuthenticateUser($WA_Auth_Parameter);
//WA Database Search Include
require_once("WADbSearch/HelperPHP.php");
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: rs_unclassified;
//Searchpage: ;
//Form: ;
if ((((isset($_POST["search1"]))?$_POST["search1"]:"") != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
//comparison list additions
$WADbSearch1->addComparison("ad_city_state","".((isset($_POST["search_location"]))?$_POST["search_location"]:"") ."","AND","Includes",0);
$WADbSearch1->addComparison("ad_header","".((isset($_POST["search_header"]))?$_POST["search_header"]:"") ."","AND","Includes",0);
$WADbSearch1->addComparison("ad_title","".((isset($_POST["search_title"]))?$_POST["search_title"]:"") ."","AND","Includes",0);
$WADbSearch1->addComparison("ad_price","".((isset($_POST["price_low"]))?$_POST["price_low"]:"") ."","AND",">=",1);
$WADbSearch1->addComparison("ad_price","".((isset($_POST["price_high"]))?$_POST["price_high"]:"") ."","AND","<=",1);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_unclassified_display1"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_unclassified_display1"]) && $_SESSION["WADbSearch1_unclassified_display1"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_unclassified_display1"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connauto, $connauto);
$query_rs_unclassified = "SELECT * FROM unclassified WHERE unclassified.ad_verify = 'Y' ORDER BY unclassified.ad_post_date DESC";
setQueryBuilderSource($query_rs_unclassified,$WADbSearch1,false);
$rs_unclassified = mysql_query($query_rs_unclassified, $connauto) or die(mysql_error());
$row_rs_unclassified = mysql_fetch_assoc($rs_unclassified);
$totalRows_rs_unclassified = mysql_num_rows($rs_unclassified);
function highlightResults($dataValue, $searchString) {
return (preg_replace("/$searchString/i", '<span style="color:red;">'.strtoupper($searchString).'</span>', $dataValue));
</head>
<body>
<div id="outerWrapper">
<div id="header">
<table width="100%"id="head_table">
<tr>
<td width="27%">&nbsp;&nbsp;&nbsp;&nbsp; <div style=" padding-top:15px."><br />
<br />
<br />
<br />
<img src="Logo/LaDollarSaverLogo_002.png" alt="LA Dollar Saver" width="234" height="51" /></div></td>
<td valign="top"><table width="100%" border="0" cellspacing="0" cellpadding="0">
<tr>
<td width="4%">&nbsp;</td>
<td><div id="logohearerdive">Introducing the Web’s First “Unclassified” <br />
<br />
Local Area Shopper. </div></td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td><br><br><br></td>
<td>&nbsp;</td>
</tr>
<tr>
<td>&nbsp;</td>
<td><div style="line-height:22px;">Find what you want here...........</div></td>
<td>&nbsp;</td>
</tr>
</table></td>
<td width="35%" valign="top"><table width="400" cellpadding="5">
<tr>
<td width="40%">Log-In Here<br />
<a href="email_pw.php" target="_blank"><span class="style2">Forgot Login</span></a>&nbsp;<span class="style2">|</span>&nbsp;<a href="anfregister.php"><span class="style2">To Register</span></a> <span class="style2">|</span>&nbsp;<span class="style2"><a href="my_account1.php">MyAccount</a></span></td>
<td width="30%">
<input name="logout1" type="submit" class="stylelogin" id="logout1" style="width: 60px;" onclick="MM_goToURL('plugins/parent','LogOut.php');return document.MM_returnValue" value="LogOut" />
</tr>
</table>
<table width="100%" cellpadding="5">
<tr>
<td><span class="style3"><?php echo(isset($_GET['failed']))? "Login is not verified. Please try again":""; ?>
</span>
<form id="login" method="post">
<table width="90%" cellpadding="5">
<tr>
<td align="right"><strong><span class="style2">Email Address:</span></strong></td>
<td><input name="user_name" type="text" id="user_name" maxlength="75" /></td>
</tr>
<tr>
<td align="right"><strong><span class="style2">Password:</span></strong></td>
<td><input type="password" name="password" id="password" />
<br /></td>
</tr>
<tr>
<td align="right">&nbsp;</td>
<td><input type="submit" name="login1" id="login1" value="LogIn" /></td>
</tr>
<tr>
<td align="right"></td>
<td></td>
</tr>
</table>
</form>
</td>
</tr>
</table>
</td>
</tr>
</table>
</div>
<div id="topNavigation">
<?php include("anf_incluse_nav.php") ?>
</div>
<div id="contentWrapper">
<div id="leftColumn1">
<h1>Unclassified Feature Items</h1>
</div>
<div id="content">
<table width="98%" border="1" cellpadding="5">
<tr align="center" valign="top">
<td><strong><em><span class="style1"><?php echo $totalRows_rs_unclassified ?> </span> Total Items from your Search</em></strong></td>
<td><a href="unclassified_display.php">New Search</a></td>
<td>&nbsp;</td>
<td>&nbsp;</td>
</tr>
<tr bgcolor="#FF9933">
<td width="25%" align="center" ><em><strong>Item Title</strong></em></td>
<td width="25%" align="center"><strong><em>Item Price</em></strong></td>
<td width="25%" align="center"><strong><em>Post Location</em></strong></td>
<td width="25%" align="center"><strong><em>Item Detail</em></strong></td>
</tr>
<?php do { ?>
<tr>
<td align="center" valign="top"><?php echo highlightResults($row_rs_unclassified['ad_title'], stripslashes($_POST["search_title"])); ?></td>
<td align="center" valign="top">$<?php echo $row_rs_unclassified['ad_price']; ?></td>
<td align="center" valign="top"><?php echo highlightResults($row_rs_unclassified['ad_city_state'], stripslashes($_POST["search_location"])); ?></td>
<td align="center" valign="top"><table>
<tr>
<td><img src="images/detail.gif" width="24" height="18" alt="Item Detail" /></td>
<td><a href="unclassified_display_detail.php?ad_ID=<?php echo $row_rs_unclassified['ad_ID']; ?>">Click Here</a></td>
</tr>
</table></td>
</tr>
<?php } while ($row_rs_unclassified = mysql_fetch_assoc($rs_unclassified)); ?>
</table>
</div>
</div>
<?php include("footer_include.php")?>
</div>
</body>
</html>
mysql_free_result($rs_unclassified);
i think the error is occurring because there is already a where clause.
try changing:
to :
$WADbSearch1_DefaultWhere = "AND 0 != 0";
JBWebWorks
That got rid of the error but it still shows all records?
JBWebWorks
I took the WHERE clause out of the recordset and used
and it works as it should.
I do need the WHERE clause that I had, so i will have to figure that out.
Any suggestions?
thanks
Jim Balthrop
add it as a condition in data assist search
select the ad_verify column and add use 'y' (without quotes) for the value.
JBWebWorks
thanks Jason
that worked filtering the ad_verify field and i used
and it shows no records when the page is accessed directly, but when a person clicks the submit button on the search page without any input in the search fields, it still shows all records.
I am using click the search form submit button as the trigger for the db search .
The search form action is the results page.
What can i do so that if the user clicks the submit button on the search form and it takes them to the results page, that no records are shown?
Here is link to the search page
click on the search unclassified button without adding any search input and it goes to the results page and shows all records?
Jim balthrop
