problems adding new content area :: Easyspace hosting??
Thread begun 8/23/2010 4:54 pm by surfbouy | Last modified 8/24/2010 10:16 am by Jason Byrnes | 2182 views | 3 replies |
surfbouyBeta Tester
Hi Guys,
I am having trouble with powerCMS2. I have installed it on an easyspace server and the site is loading up but I can't add any content areas. it just comes back to the index.php page without content being added.
I received an error when playing with it when i pushed advance search. This is the error
Warning: mysql_pconnect() [function.mysql-pconnect]: User fogdmn737 already has more than 'max_user_connections' active connections in /vhost/vhost8/l/i/f/lifesagym.com/www/siteupdate/Connections/PowerCMSConnection.php on line 9
Fatal error: User fogdmn737 already has more than 'max_user_connections' active connections in /vhost/vhost8/l/i/f/lifesagym.com/www/siteupdate/Connections/PowerCMSConnection.php on line 9
I sent this to easy host and they suggested the following.
Hello,
Thank you for contacting Easyspace. we would recommend using mysql_connect rather than pconnect on our servers. Can you please try this and let us know if you are still having issues.
Thanks again guys...
Craig Jones
P.S I downloaded new files and installed again as suggested to someone else in forum
in the Connections/PowerCMSConnection.php file
change:
$PowerCMSConnection = mysql_pconnect($hostname_PowerCMSConnection, $username_PowerCMSConnection, $password_PowerCMSConnection) or trigger_error(mysql_error(),E_USER_ERROR);
$PowerCMSConnection = mysql_connect($hostname_PowerCMSConnection, $username_PowerCMSConnection, $password_PowerCMSConnection) or trigger_error(mysql_error(),E_USER_ERROR);
surfbouyBeta Tester
half way there...
Hi Jason
thanks for your speedy reply
It has fixed the search but I still can't add content.
Craig
