No Preview Help!!
Thread begun 8/23/2010 10:24 am by tsunami.rob362669 | Last modified 10/22/2010 8:33 am by Jason Byrnes | 4491 views | 9 replies |
tsunami.rob362669
No Preview Help!!
I am having no preview on all of the webassist products! I have tried several solutions from the online forum but still no luck. I also tried reinstalling every single one of the extensions and the problem still persist. Please Help!!
peder232091
No preview either
Hi, I have actually the same issue with my recently installed version with CS3. Would also appreciate a solution :)
Cheers,
-Peder
when we investigated with the original poster on the phone, we found the problem was caused a toolbar that was installed into safari.
can you try disabling any add on's that you have in safari like third part toolbars.
if you click in the preview window, does it open the preview in the browser?
peder232091
Hi, well I haven't Safari installed only using IE, Firefox and Chrome as installed browsers. When clicking it does open the page in the browser. Using Chrome as default browser, maybe that is the issue will check.
Cheers,
-P
what is the address in the address bar?
what version of IE?
What is your OS?
peder232091
Hi Jason, running XP and IE 8 and this is what shows in the address bar;
C:\Documents and Settings\Administratör\Application Data\Adobe\Dreamweaver 9\Configuration\Shared\WebAssist\Preview\wa_sitesculptor_home.html
I did set so IE is default browser but with same result.
Cheers,
-P
this is an issue with running the extensions under the windows administrator account.
you should create a new windows user and install the extension under that user.
peder232091
Jason, thanks that did the trick :)
Cheers,
-P
excellent, glad to hear it is working.
