Checkout Success Page Not Displaying
Thread begun 8/23/2010 8:29 am by vmartinez310076 | Last modified 8/24/2010 7:19 am by Jason Byrnes | 4056 views | 7 replies |
vmartinez310076
After clicking the "Submit" button on the confirm page it processes the order, but re-displays the confirm page and not the success page. The order is entered into the database and the Authorize.net email receipt is sent.
Any help will be greatly appreciated.
sounds like there is a php error occurring that is preventing the redirect to the success page.
add the following to line 1 to turn error reporting on to see what the error is:
error_reporting
(E_ALL);
vmartinez310076
It did not through any errors. Any other ideas?
can you send a copy of the confirm page
vmartinez310076
Attached is a zip file with the confirm page code.
add the following code just before the doc type tag:
// WA eCart Redirect
if ($bibbieCart->redirStr != "")     {
header("Location: ".$bibbieCart->redirStr);
vmartinez310076
Thank you. That fixed the problem. Do you know why eCart 5 didn't insert the code on creation?
Thanks again,
Vince
I cant say, it should have been added there.
Any time I have used the checkout wizard, the code was added, i have not been able to reproduce the problem in order to investigate the cause.
