Security Assist not adding helper files to the site
Thread begun 8/22/2010 5:37 am by phebberd116714 | Last modified 8/31/2010 7:22 am by Jason Byrnes | 6732 views | 14 replies |
phebberd116714
I am using the latest version of Security Assist on a Mac running Snow Leopard.
After completing the forgot password page with the Random Password generator and Encryption, the helper files for these are not being added to the WA_SecurityAssist folder.
I have removed and reinstalled Security Assist and also deleted the dat file a number of times.
I checked the config library and the files are in SecurityAssist > Helpers.
My quick fix is to just copy the files to the site, but is there a real fix for this problem?
This is an issue that a few people are running into, however, we have not been able to find the cause in order to find a solution.
Could you post back screen shots showing your site definition settings? especially the Local Info and Testing server tabs.
phebberd116714
Screen shots
Here are the screenshots for all 3 tabs.
My local root directory is: /Users/paulmait/Documents/MyWebSites/CROWLANE on PaulsTestSpace
I think the problem may be caused by using a remote FTP testing server.
I think using a local testing instead of remote may fix the issue.
see the tutorials for installing a local testing server on the learning resources page:
resources.php
phebberd116714
Your Solution Worked
Thanks Jason,
I did a quick test using MAMP and the files were indeed added correctly.
The obvious bonus is that using my MAMP server for testing is a whole lot faster than having the files upload to the remote server every time I make a change to a page.
OK, thanks for posting back your results.
anonymous
Jason and crew,
I have run into a similar bug as well (on Mac Snow Leopard too) but I found out after applying SHA1 encryption what was going on. For some reason Security Assist will put the Security Assist helper folder up one level outside my public html folder. Very strange.
So, in my case, it actually is creating the folder and files - but it is putting them outside the public html folder.
For example, all of my sites follow this hierarchy:
SITENAME
Assets & public_html
After running a Security Assist function, I now have
SITENAME
Assets - public_html - Security Assist Folder
Took me forever to figure out what was going on with it, but that seems to be it.
Best regards,
Brian
Thank you for reporting this Brian
carleneBeta Tester
Is there another resolution for this other than working on a local test server? I'm trying to work on a live server and need to work on a live server always. Was this resolved by the files being put up in the hierarchy? Is there a bug fix revision in the works then?
carleneBeta Tester
Also could someone post a list of the helper file names that are supposed to be created and where exactly they should be located on the site?
