default image
Thread begun 8/21/2010 5:53 am by i.edwards384429 | Last modified 8/23/2010 10:29 am by Jason Byrnes | 1632 views | 3 replies |
i.edwards384429
default image
Hi
At
users_Registration.php
is the registration solution with lots of modifications and all works.
I've added ten upload fields which do upload and update the database!!!!
In the table design I set the default to be noimage.jpg which is a place holder image for use if the user does not upload an image.
However when I fill in the form if I upload no images then it seems that a null value is written into the database so no default image is listed.
Clearly yet again I've missed something, is there a box i've forgotten to tick?
thanks
Ian
SET FOREIGN_KEY_CHECKS=0;
-- Table structure for users
DROP TABLE IF EXISTS `users`;
CREATE TABLE `users` (
`UserID` int(11) NOT NULL auto_increment,
`UserEmail` varchar(500) default NULL,
`UserPassword` varchar(500) default NULL,
`UserFirstName` varchar(50) default NULL,
`UserLastName` varchar(50) default NULL,
`UserCity` varchar(90) default NULL,
`UserState` varchar(20) default NULL,
`UserZip` varchar(12) default NULL,
`UserContactHours` varchar(12) default NULL,
`UserEmailVerified` tinyint(1) default '0',
`UserRegistrationDate` timestamp NULL default CURRENT_TIMESTAMP,
`UserVerificationCode` varchar(20) default NULL,
`UserIP` varchar(50) default NULL,
`UserPhone` varchar(20) default NULL,
`UserFax` varchar(20) default NULL,
`UserCountry` varchar(20) default NULL,
`UserAddress` varchar(100) default NULL,
`UserAddress2` varchar(50) default NULL,
`UserSex` varchar(20) default NULL,
`UserEthnicity` varchar(20) default NULL,
`UserAge` varchar(20) default NULL,
`UserTypes` varchar(20) default NULL,
`UserArea` varchar(20) default NULL,
`UserImage1` varchar(20) default 'noimage.jpg',
`UserImage2` varchar(20) default 'noimage.jpg',
`UserImage3` varchar(20) default 'noimage.jpg',
`UserImage4` varchar(20) default 'noimage.jpg',
`UserImage5` varchar(20) default 'noimage.jpg',
`UserImage6` varchar(20) default 'noimage.jpg',
`UserImage7` varchar(20) default 'noimage.jpg',
`UserImage9` varchar(20) default 'noimage.jpg',
`UserImage8` varchar(20) default 'noimage.jpg',
`UserImage10` varchar(20) default 'noimage.jpg',
`UserEyeColour` varchar(20) default NULL,
`UserHairColour` varchar(20) default NULL,
`UserHips` varchar(20) default NULL,
`UserWaist` varchar(20) default NULL,
`UserBustChest` varchar(20) default NULL,
`UserHeight` varchar(20) default NULL,
`UserWeight` varchar(20) default NULL,
`UserHatSize` varchar(20) default NULL,
`UserDressSize` varchar(20) default NULL,
`UserSmoker` varchar(20) default NULL,
`UserDistinguishingFeatures` varchar(50) default NULL,
`UserShoeSize` varchar(20) default NULL,
`UserGloveSize` varchar(20) default NULL,
`UserModellingExperience` varchar(50) default NULL,
PRIMARY KEY (`UserID`)
) ENGINE=MyISAM AUTO_INCREMENT=127 DEFAULT CHARSET=latin1;
In the upload file server behavior, set the Default File to 'noimage.jpg'
i.edwards384429
update
Thanks Jason
as usual looking for a complicated solution when a simple one was there ;-(
cheers
Ian
you're welcome.
