Captcha graphic in css form builder
Thread begun 8/20/2010 8:49 am by gwh362692 | Last modified 9/02/2010 8:46 am by Jason Byrnes | 7089 views | 15 replies |
gwh362692
Hi all,
I'm trying to alter the clarity of a captcha graphic created with CSS form builder. I went into the wizard along this path:
Edit design > Form elements > captcha
I tried changing things like, the noise, font, grid etc. then I press apply and finished the wizard but the graphic doesn't change. I've tried it about 10 times and it doesn't work.
Can anyone point out what I'm doing wrong?
Thanks in advance.
That is the correct way to go about editing the captcha properties, I just tested on a form I created and the changes are being made.
the changes are applied as query string variables to the WAVT_CaptchaSecurityImages.php file. For example, the changes I made in my test changed the img tag from:
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Log_in_group_Security_code&font=Fonts/MOM_T___.TTF" alt="Security Code" class="Captcha" />
<img src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Log_in_group_Security_code&bgcolor=FF6633&transparent=false&noisefreq=25&noisecolor=99CCCC&gridfreq=50&gridcolor=999999&gridorder=0&font=Fonts/MOM_T___.TTF&characters=7" alt="Security Code" class="Captcha" />
can you see any changes in the image source on your page?
gwh362692
Thanks for the reply,
The following is the content of my WAVT_CaptchaSecurityImages.php:
<code>
session_start();
class WA_Captcha {
function randomString($numChars) {
$useChars = '2345679bcdhkmnrstwxzADEFHJKLMNPRSTWXYZ';
$str = '';
for ($x = 0; $x < $numChars; $x++) {
$str .= substr($useChars, rand(0, strlen($useChars)-1), 1);
return $str;
function hexToRGB($color) {
if ($color[0] == '#')
$color = substr($color, 1);
if (strlen($color) == 6)
list($r, $g, $b) = array($color[0].$color[1],
$color[2].$color[3],
$color[4].$color[5]);
elseif (strlen($color) == 3)
list($r, $g, $b) = array($color[0].$color[0], $color[1].$color[1], $color[2].$color[2]);
else
return false;
$r = hexdec($r); $g = hexdec($g); $b = hexdec($b);
return array($r, $g, $b);
function addGrid($image,$freq,$width,$height,$color) {
if ($freq != 0) {
$frequency = (101-$freq);
// horizontal line
$numLines = ceil($height/$frequency);
$shift = rand(1,$frequency-1);
for( $i=0; $i<$numLines; $i++ ) {
imageline($image, 0, ($frequency*$i)+$shift, $width, ($frequency*$i)+$shift, $color);
// vertical line
$numLines = ceil($width/$frequency);
imageline($image, ($frequency*$i)+$shift, 0, ($frequency*$i)+$shift, $height, $color);
// backslash line
imageline($image, ($frequency*$i)+$shift+$frequency, 0, ($frequency*$i)+$shift, $height, $color);
// slash line
imageline($image, ($frequency*$i)+$shift, 0, ($frequency*$i)+$shift+$frequency, $height, $color);
function addNoise($image,$freq,$width,$height,$color) {
if ($freq != 0) {
$frequency = $freq;
// random noise
$noiseSpots = ($width*$height*($frequency/20))/5;
for( $i=0; $i<$noiseSpots; $i++ ) {
imagefilledellipse($image, rand(0,$width), rand(0,$height), 1, 1, $color);
// random line
$numLines = (($height/60)*sqrt($width*$height)*($frequency/20))/5;
imageline($image, rand(0,$width), rand(0,$height), rand(0,$width), rand(0,$height), $color);
function WA_Captcha($width,$height,$characters,$bg_color,$text_color,$noise_color,$font,$field,$transparent,$bgimage,$gridfreq,$grid_color,$gridorder,$noisefreq,$noiseorder,$charheight) {
$font = realpath($font);
$font_size = $charheight;
if ($bgimage != "") {
$image_size = getimagesize($bgimage);
if (strpos($bgimage,".gif") > 0) {
$captchaBG = imagecreatefromgif($bgimage);
else if (strpos($bgimage,".png") > 0) {
$captchaBG = imagecreatefrompng($bgimage);
else {
$captchaBG = imagecreatefromjpeg($bgimage);
$captcha = imagecreatetruecolor($width, $height);
$ystart=0;
$bgColor = $this->hexToRGB($bg_color);
$txtColor = $this->hexToRGB($text_color);
$noiseColor = $this->hexToRGB($noise_color);
$gridColor = $this->hexToRGB($grid_color);
$background_color = imagecolorallocate($captcha, $bgColor[0], $bgColor[1], $bgColor[2]);
$text_color = imagecolorallocate($captcha, $txtColor[0], $txtColor[1], $txtColor[2]);
$noise_color = imagecolorallocate($captcha, $noiseColor[0], $noiseColor[1], $noiseColor[2]);
$grid_color = imagecolorallocate($captcha, $gridColor[0], $gridColor[1], $gridColor[2]);
imagefilledrectangle($captcha,0,0,$width,$height,$background_color);
if ($transparent == 1) imagecolortransparent($captcha, $background_color);
while($ystart<=$height) {
$xstart=0;
while($xstart<=$width) {
imagecopy($captcha, $captchaBG, $xstart, $ystart, 0, 0, $image_size[0], $image_size[1]);
$xstart += $image_size[0];
$ystart += $image_size[1];
if ($noiseorder != "in front of text") {
$this->addNoise($captcha,$noisefreq,$width,$height,$noise_color);
if ($gridorder != "in front of text") {
$this->addGrid($captcha,$gridfreq,$width,$height,$grid_color);
$captcha_string = $this->randomString($characters);
$y = -1;
while ($y < 0 || ($textbox[4] > $width)) {
$textbox = imagettfbbox($font_size, 0, $font, $captcha_string);
$y = ($height - $textbox[5])/2;
if ($y < 0 || ($textbox[4] > $width)) {
$font_size = 0.9 * $font_size;
$totWidth = 0;
$charWidths = array();
for ($charLen=0;$charLen<$characters;$charLen++) {
$tilt = rand(-15,15);
$charWidth = imagettfbbox($font_size, $tilt, $font, $captcha_string[$charLen]);
$tilts[] = $tilt;
$charWidths[] = $charWidth[4];
$totWidth += $charWidth[4];
$space = ($width-$totWidth)/($characters+2);
$x = $space*1.5;
imagettftext($captcha, $font_size, $tilts[$charLen], $x, $y, $text_color, $font , $captcha_string[$charLen]);
$x += $charWidths[$charLen]+$space;
if ($noiseorder == "in front of text") {
if ($gridorder == "in front of text") {
header('Content-Type: image/png');
imagepng($captcha);
imagedestroy($captcha);
$_SESSION["captcha_".$field] = $captcha_string;
$width = isset($_GET['width']) && $_GET['width'] != "" ? $_GET['width'] : '120';
$height = isset($_GET['height']) && $_GET['height'] != "" ? $_GET['height'] : '40';
$characters = isset($_GET['characters']) && $_GET['characters'] > 2 ? $_GET['characters'] : '5';
$bgcolor = isset($_GET['bgcolor']) && $_GET['bgcolor'] != "" ? $_GET['bgcolor'] : 'FFFFFF';
$textcolor = isset($_GET['textcolor']) && $_GET['textcolor'] != "" ? $_GET['textcolor'] : '000000';
$noisecolor = isset($_GET['noisecolor']) && $_GET['noisecolor'] != "" ? $_GET['noisecolor'] : '000000';
$font = isset($_GET['font']) && $_GET['font'] != "" ? $_GET['font'] : 'Fonts/MOM_T___.TTF';
$field = isset($_GET['field']) && $_GET['field'] != "" ? $_GET['field'] : '1';
$transparent = isset($_GET['transparent']) && $_GET['transparent'] != "" ? $_GET['transparent'] : '0';
$bgimage = isset($_GET['bgimage']) && $_GET['bgimage'] != "" ? $_GET['bgimage'] : '';
$gridfreq = isset($_GET['gridfreq']) && $_GET['gridfreq'] != "" ? $_GET['gridfreq'] : '50';
$gridcolor = isset($_GET['gridcolor']) && $_GET['gridcolor'] != "" ? $_GET['gridcolor'] : '000000';
$gridorder = isset($_GET['gridorder']) && $_GET['gridorder'] != "" ? $_GET['gridorder'] : '';
$noisefreq = isset($_GET['noisefreq']) && $_GET['noisefreq'] != "" ? $_GET['noisefreq'] : '50';
$noiseorder = isset($_GET['noiseorder']) && $_GET['noiseorder'] != "" ? $_GET['noiseorder'] : '';
$charheight = isset($_GET['charheight']) && $_GET['charheight'] != "" ? $_GET['charheight'] : $height*0.75;
Fonts/MACTYPE.TTF
Fonts/MODERNA_.TTF
Fonts/MOM_T___.TTF
Fonts/monofont.ttf
$captcha = new WA_Captcha($width,$height,$characters,$bgcolor,$textcolor,$noisecolor,$font,$field,$transparent,$bgimage,$gridfreq,$gridcolor,$gridorder,$noisefreq,$noiseorder,$charheight);
</code>
I did a search for the code you gave, ie.
but it didn't exist in the file.
Should it be there?
the image code will not be in the WAVT_CaptchaSecurityImages.php file, it will be in your form page.
gwh362692
Before changing anything, the code was as follows:
<img src="../WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Send_enquiry_group_Security_code&transparent=false&font=Fonts/MODERNA_.TTF" alt="Security Code" class="Captcha" />
Then I changed the following:
1) the font family to Moderna
2) grid size to none
3) noise amount to none
And the code changed to the this:
<img src="../WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Send_enquiry_group_Security_code&transparent=false&noisefreq=25&gridfreq=50&font=Fonts/MACTYPE.TTF" alt="Security Code" class="Captcha" />
But the captcha image doesn't look any different. I mean the noise is completely the same even though I set it to none.
I'm using Mac OS 10.5.8. Could this be a bug?
can you send a link where can see the issue?
gwh362692
Sorry about the delay in getting back about this issue.
You can see it at the following url:
contact
In addition to the captcha problem, if you type in the security incorrectly and then press submit, the form just reloads. It doesn't send any of the information and there's no cue to the person filling in the form that there was any error. Is this a bug and if so is it fixable?
when i view source of you page, the image tag does not appear to heave changed:
<img class="Captcha" alt="Security Code" src="WA_ValidationToolkit/WAVT_CaptchaSecurityImages.php?field=Send_enquiry_group_Security_code&transparent=false&font=Fonts/MODERNA_.TTF">
make sure that the upload of the contact page is actually completeing successfully, Dreamweaver can be problematic when uploading files, i often add a visual change to the page such as adding today's date so i can be sure the page uploaded successfully.
for the validation failure issue, find the following code:
if ($WAFV_Errors != "")  {
    PostResult($WAFV_Redirect,$WAFV_Errors,"confirm");
and change it to:
    die($WAFV_Errors);
this will write a comma separated list of failed validations to the screen post this back with copy of your page in a zip archive and I will be able to troubleshoot the issue.
gwh362692
The page did upload correctly. That's actually the code I have on my local site. I changed it again but the font is definitely not Moderna and the noise is still really heavy.
Regarding the code you asked me to find, the closest I could find was:
PostResult($WAFV_Redirect,$WAFV_Errors,"contactform");
There was no other code that included the "confirm" part. I even even did a site wide search and couldn't find it. I don't know what's going on.
I will need you to upload the code to the server so i can see the issue to troubleshoot it.
this is the correct code:
change it to:
die($WAFV_Errors);
