Proplem with the paypal SANDBOX!!
Thread begun 8/20/2010 2:16 am by antoniocerasuolo411297 | Last modified 9/10/2010 9:15 am by Jason Byrnes | 11628 views | 52 replies |
I am having trouble with the paypal sandbox.. i put in the debugging on the pp_checkout_failure.php page and am getting the following below: can anyone help me???? what is the problem??
Direct Pay:
Express Authorize
<?xml version="1.0" encoding="utf-8"?><soap:Envelope xmlns:soap="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><soap:Header><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents"><Username>antoni_1281564546_biz@hotmail.com</Username><Password>1281564553</Password><Signature>A-m3fRYlLDrTzS2.Zvmjiday.IDCA5FAQnVWxsOjwtWFwbvbg78Mea8r</Signature><Subject/></Credentials></RequesterCredentials></soap:Header><soap:Body><SetExpressCheckoutReq xmlns="urn:ebay:api:PayPalAPI"><SetExpressCheckoutRequest><Version xmlns="urn:ebay:apis:eBLBaseComponents">60.0</Version><SetExpressCheckoutRequestDetails xmlns="urn:ebay:apis:eBLBaseComponents"><ReturnURL>http://mylombardy.com/pp_confirm.php</ReturnURL><CancelURL>http://mylombardy.com/pp_cancel.php</CancelURL><PaymentAction>Authorization</PaymentAction><PaymentDetails><OrderTotal currencyID="USD">480.00</OrderTotal></PaymentDetails></SetExpressCheckoutRequestDetails></SetExpressCheckoutRequest></SetExpressCheckoutReq></soap:Body></soap:Envelope>
<?xml version="1.0" encoding="UTF-8"?><SOAP-ENV:Envelope xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/" xmlns:SOAP-ENC="http://schemas.xmlsoap.org/soap/encoding/" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:cc="urn:ebay:apis:CoreComponentTypes" xmlns:ed="urn:ebay:apis:EnhancedDataTypes" xmlns:wsu="http://schemas.xmlsoap.org/ws/2002/07/utility" xmlns:saml="urn:oasis:names:tc:SAML:1.0:assertion" xmlns:ds="http://www.w3.org/2000/09/xmldsig#" xmlns:wsse="http://schemas.xmlsoap.org/ws/2002/12/secext" xmlns:ebl="urn:ebay:apis:eBLBaseComponents" xmlns:ns="urn:ebay:api:PayPalAPI"><SOAP-ENV:Header><Security xmlns="http://schemas.xmlsoap.org/ws/2002/12/secext" xsi:type="wsse:SecurityType"></Security><RequesterCredentials xmlns="urn:ebay:api:PayPalAPI" xsi:type="ebl:CustomSecurityHeaderType"><Credentials xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:UserIdPasswordType"><Username xsi:type="xs:string"></Username><Password xsi:type="xs:string"></Password><Signature xsi:type="xs:string">A-m3fRYlLDrTzS2.Zvmjiday.IDCA5FAQnVWxsOjwtWFwbvbg78Mea8r</Signature><Subject xsi:type="xs:string"></Subject></Credentials></RequesterCredentials></SOAP-ENV:Header><SOAP-ENV:Body id="_0"><SetExpressCheckoutResponse xmlns="urn:ebay:api:PayPalAPI"><Timestamp xmlns="urn:ebay:apis:eBLBaseComponents">2010-08-20T08:56:26Z</Timestamp><Ack xmlns="urn:ebay:apis:eBLBaseComponents">Failure</Ack><CorrelationID xmlns="urn:ebay:apis:eBLBaseComponents">862c02b45626c</CorrelationID><Errors xmlns="urn:ebay:apis:eBLBaseComponents" xsi:type="ebl:ErrorType"><ShortMessage xsi:type="xs:string">Security error</ShortMessage><LongMessage xsi:type="xs:string">Security header is not valid</LongMessage><ErrorCode xsi:type="xs:token">10002</ErrorCode><SeverityCode xmlns="urn:ebay:apis:eBLBaseComponents">Error</SeverityCode></Errors><Version xmlns="urn:ebay:apis:eBLBaseComponents">60.0</Version><Build xmlns="urn:ebay:apis:eBLBaseComponents">1445048</Build></SetExpressCheckoutResponse></SOAP-ENV:Body></SOAP-ENV:Envelope>
Express Process
I may have copied some leading spaces of the signature in the main setup of the checkout wizard..
do i need to run the wizard again to fix this?
I just cheched the chechout.php and as you can see there are no spaces before or after in API but would the spaces show up here?? but i really don't think this is the problem!! I beleive it is an outright problem on the paypayl system itself.. by the way i copy pasted the new PP_ECO_PHP.php as was suggested in other similar thread.
WHAT are you suggesting i do to get this issue solved??? am running out of ideas :-)
$nextIndex = count($WA_PP_ECO_Set_params[0]);
$WA_PP_ECO_Set_params[0][$nextIndex] = "Username";
$WA_PP_ECO_Set_params[1][$nextIndex] = "antoni_1281564546_biz_api1.hotmail.com";
$WA_PP_ECO_Set_params[0][$nextIndex] = "Password";
$WA_PP_ECO_Set_params[1][$nextIndex] = "1281564553";
$WA_PP_ECO_Set_params[0][$nextIndex] = "Signature";
$WA_PP_ECO_Set_params[1][$nextIndex] = "A-m3fRYlLDrTzS2.Zvmjiday.IDCA5FAQnVWxsOjwtWFwbvbg78Mea8r";
$W
Should I just try to get new API credentials?? and maybee that would do the trick?
the error you are getting is:
This error means there is an issue with the credentials, either they are not Sandbox credentials, or you are passing the transacrtion through the live server.
To check if you are passing through the live server look for the following on the checkout page:
$WA_PP_ECO_Set_params[0][$nextIndex] = "UseSandbox";
to use the sandbox, the next line should be set to true:
$WA_PP_ECO_Set_params[1][$nextIndex] = "true";
I'm not entirely sure the api username you are using is a Sandbox username, I thought the sandbox user names usually had 'test' in them somewhere, you should double check that these API credentials are actually tesst credentals.
See the following PDF for detail on getting sandbox API credentials:
paypal_sandbox.pdf
source neenwed
Jason,
these are sandbox credentials!!
I asked for new test credentials and but them into the checkout page by hand copy/pate carefully
but now am getting this error when i got to the checkout page:
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at D:\inetpub\vhosts\mylombardy.com\httpdocs\checkout.php:1) in D:\inetpub\vhosts\mylombardy.com\httpdocs\WA_eCart\WA_eCart_Definition_PHP.php on line 465
headers already sent means that there is output to the page
the error is reporting the outpout at line 1:
checkout .php:1
Often times when the error is reported at line 1, it is because the unicode signatureBOM is applied to the page.
Go to Modify Page properties.
In the title and encoding Section, make sure the Include Unicode Signature (BOM) is Not checked.
if you still have a problem, look for a blank line or space in the page outside the php tags at line 1.
Jason,
i'm herer at my office and dont have dreamweaver.. am using notepad2 :-) as soon as i get home i will do what you say but what should i exactly do ??
thanx
Jason,
ok i used the ITf -8 property..
anyhow.. you won't beleive this .. the sand box is working now!
this is a miracle!
thanx!
Excellent, glad to hear it is working.
