WA_RandomPassword.php Not Generated
Thread begun 8/19/2010 8:22 am by htp372188 | Last modified 1/06/2011 8:21 am by Andrew Read | 3800 views | 4 replies |
htp372188
I am getting the following error message when trying to log-in through a page generated by SecurityAssist:
Warning: require_once(../WA_SecurityAssist/WA_RandomPassword.php) [function.require-once]: failed to open stream: No such file or directory in . . .
I checked and the file is indeed missing.
this is an issue a few users are reporting that we are trying to determine the cause of.
Some people have reported that the files gets created a directory down from the Dreamweaver root for some reason. You can download a copy of the files from this post:
showpost.php?p=32196&postcount=2
and copy them into the WA_SecurityAssist folder of your site.
htp372188
I've seen the same thing before w/ DataAssist. Thanks for your prompt response.
You're welcome.
Andrew Read
Known Issue - AGAIN. :)
Hi all,
Any reason that this has not hit the download area as a "Known Issues" for this extension yet? I remember seeing this ages ago - and I had to relearn about it all again today, time wasted is time I'm not billing my clients. ;)
I also think that a sticky in the Forum for each extension with these known issues would be fantastic - this is always where I come to look for solutions first.
Thanks.
