Error When Checking Out On My Local Mysql database
Thread begun 8/17/2010 10:58 pm by nathan400860 | Last modified 8/18/2010 7:17 am by Jason Byrnes | 1061 views | 1 replies |
nathan400860
Hello,
I have just generated and created my checkout wizard pages / check out pages. I am using authorize net and have linked my api id and transaction key into my site when I was setting up my checkout pages. After I get passed the Confirm page I get this error.
"You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Mitchell Thicken Up ,'Paul Mitchell Thicken Up ',15.5,1)' at line 1"
I believe this error has something to do with my local database.
Thanks,
Nate Swan
the issue is that the value "Mitchell Thicken Up" is trying to be passed to a column in the database that is set to be numeric.
I can only guess, but it seams like the items name is also being used as the items ID. the item ID should be a numeric value.
