Ecart add to cart button not working when dfp download is on same page.
Thread began 8/17/2010 9:36 pm by blackweldermhe400113 | Last modified 8/18/2010 7:22 am by Jason Byrnes | 1114 views | 1 replies |
I'm having a problem when an instance of the ecart add to cart button and the dfp download button are on the same page. They both will work independent of each other but if I have both applied to the same page the add to cart button no longer works. The add to cart button when hit tries to download the source for the page that it is present on. So, for example, if they both were on the audio.php the add to cart would prompt a download for the audio.php page. Do you have any idea what this could be? I've attached my audio.php file. Thanks!
audio.zip
The trigger being used for the download file behavior is currant page submit, it will try to download the file any time the page submits to itself, meaning if the add to cart button is pressed.
you should change the trigger to Button: download pressed so the download will only occur the download button is pressed and will not occur if the add to cart button is pressed.
For more details on triggers, see the following pdf:
triggers.pdf
