2.0.5 crashed my Dreamweaver CS4
Thread begun 6/07/2009 1:30 pm by InnovaDave | Last modified 9/01/2009 3:14 pm by Ray Borduin | 4472 views | 3 replies |
InnovaDave
I unistalled 2.0.4 and then installed the new 2.0.5. Restarted DW CS4 and then went to use DataAssist and got the old... "Adobe Dreamweaver CS4 has encountered a problem and needs to close. We are sorry for the inconvenience." and it shut down my DW.
After 2.0.5 crashed my system, I went back and uninstalled it and installed 2.0.4 and now it crashes as well. Please let me know how to fix the issue, I'm working on a project that need to be done soon.
Thanks,
Dave
Try deleting your winfilecache .dat file. That is usually the culprit with issues like this.
info47469
I'm deleting the macfilecache.dat but the problem persists.
Data Assist worked well two o three days. It suddenly CS4 (Mac) close. The application create the first page "results.php" but with the second page Dreamweaver crashed.
I uninstalled and reinstalling the extension, but nothing.
Can help me, please?
Thanks,
Juaco
It might be a problem with the particular template or database you are using. Try to narrow it down. Does it work if you don't use a template when applying? Does it work with a different database table? Does it work on a different site with a different database connection?
It should reset things when deleting the cache file. This isn't a common problem so I can't say for sure the cause with the limited information provided. Maybe try those tests and let me know the results and I can maybe figure it out or give you more tests to try from there.
