Confirm Page not sending email to customer - PS2
Thread begun 8/16/2010 6:40 am by robert329616 | Last modified 8/17/2010 8:19 am by Jason Byrnes | 7718 views | 8 replies |
robert329616
Hello,
I am having an issue when I test my site using Power Store 2.
Everything works up until I confirm the order (I am using direct pay with paypal, not paypal express). The order receipt page shows but the email is not sent to the customer. I went through the forum over the weekend and applied the fix's that I found including downloading the new confirm.php page from known solutions.
None worked. When I use that confirm page the order receipt page does not show but the email receipt is sent. I saw in one of the threads that another person had the same issue but there wasn't a fix.
I also added the code to show errors but none showed up. Also, all of the other emails send fine from the site.
Thanks for the help.
Rob
OK, so the updated power store files fixed the mail sending problem, but now the redirect to the success page is not working.
To trouble shoot the redirect issue, add the following code at line 1 of the confirm page:
error_reporting(E_ALL);
ini-set('display_errors','on');
?>[/php]
most likely, a php error is occurring that is preventing the redirect. this code will turn error reporting on, post back any errors you see so we can troubleshoot the issue.
robert329616
Jason,
This is the error I am getting:
Notice: Use of undefined constant ini - assumed 'ini' in /home/content/v/f/c/vfcreative/html/bpstest/confirm.php on line 3
Fatal error: Call to undefined function set() in /home/content/v/f/c/vfcreative/html/bpstest/confirm.php on line 3
Not sure why it would be line three since that is the error display code.
Rob
my apologies, there was a typo in the previous code, it should be:
error_reporting
(E_ALL);
robert329616
I am not sure what happened but the page is not working at all now, it does not update the db or send an email.
I added you code to the top but it did not show any errors. I did find and add another code that gave the following errors:
Warning: include(file_with_errors.php) [function.include]: failed to open stream: No such file or directory in /home/content/v/f/c/vfcreative/html/bpstest/confirm.php on line 4
Warning: include() [function.include]: Failed opening 'file_with_errors.php' for inclusion (include_path='.:/usr/local/php5/lib/php') in /home/content/v/f/c/vfcreative/html/bpstest/confirm.php on line 4
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /home/content/v/f/c/vfcreative/html/bpstest/confirm.php:4) in /home/content/v/f/c/vfcreative/html/bpstest/WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php on line 3
The code was:
ini_set("display_errors", 1);
include("file_with_errors.php");
Hopefully this helps.
Thanks.
Rob
robert329616
Jason,
I went back to the beginning where everything worked except the email.
I then copied the known issue confirm.php file to give it another try but it gave me the same issues. There were no errors shown on my orig file (bpstest/).
Is there any way to fix the email problem starting with the confirm.php file I have posted and attached? All of the other email functions are working as well.
Rob
change line 1064:
$WA_redirectURL = "checkout_success.php";
$WA_redirectURL = "";
then change line 1117 - 1120
//Send Mail All Entries
  if (""!="")     {
    header("Location: ");
  if ("checkout_success.php"!="")     {
    header("Location: checkout_success.php");
robert329616
Jason,
That worked perfectly, thanks so much for the help!
Rob
Excellent, glad to hear it is working.
