Cannot Edit Menu
Thread begun 8/15/2010 2:08 pm by Brad Lawryk | Last modified 8/17/2010 8:29 am by Jason Byrnes | 2454 views | 4 replies |
Brad Lawryk
Cannot Edit Menu
A couple of problems:
1) It seems that WA CSS Menus is the only third party menu generator that will work with a page generated by CSS Sculptor and using the Framework. Others that I have tried all mess up the page layout. So I was forced to use the WA one.
2) I can insert a menu and it works fine until I go to edit and actually add in my proper links etc. The editor works and makes the changes but as when I am done and click on Finish I get the following error and no changes are saved.
Dreamweaver
Error generating menu (wa.generate.menu):
TypeError: this.orientations[orientation] has no properties
OK
Brad Lawryk
Also, the WA created menu does not show up in design view in DW. Actually nothing shows up when included as a plug in.
Should at least have a placeholder or something to indicate the is a menu there?
Brad
Brad Lawryk
Thanks Jason,
Never did hear back from the ticket, but the problem is solved and I have closed the ticket. It works as it should now.
Noticed in the patchnotes that this was an issue that was fixed and I wasn't using the latest version.
Brad
OK, glad to hear this is working.
