Building a Dynamic Where Clause
Thread begun 8/13/2010 7:47 am by dnys04173367569 | Last modified 8/23/2010 8:30 am by Jason Byrnes | 1928 views | 3 replies |
dnys04173367569
Problem - I wish to use a filter within the results page - i.e. Dropdown List - to allow selection of products by price range. Once the search has been made or result page loaded.
if (isset($_GET["ProductOccasionID"]) && isset($_GET["Search"])) {
if ($WADbSearch1->whereClause != "") {
$WADbSearch1->whereClause .= " AND ";
$WADbSearch1->whereClause .= "ProductID IN (SELECT ProductID FROM productoccasions WHERE (OccasionID = ".implode($_GET["ProductOccasionID"]," OR OccasionID = ")."))";
$_SESSION["WADbSearch1_Admin_Products_Results"]=$WADbSearch1->whereClause;
If I manually alter the line as follows:-
$WADbSearch1->whereClause .= " AND (ProductPrice >= 10.00) & (ProductPrice <= 25.00) AND ProductID IN (SELECT ProductID FROM productoccasions WHERE (OccasionID = ".implode($_GET["ProductOccasionID"]," OR OccasionID = ")."))";
The data is selected as requested. However, I need this to be dynamic for the filter to work properly.
I am trying to get the whereclause to include a $price_query string. Something like
$WADbSearch1->whereClause .= $price_query . "ProductID IN (SELECT ProductID FROM productoccasions WHERE (OccasionID = ".implode($_GET["ProductOccasionID"]," OR OccasionID = ")."))";
Whereby $price_query holds the text element " AND (ProductPrice >= 10.00) & (ProductPrice <= 25.00) AND " and gets appended in front of the Original whereClause text ProductID IN (SELECT ProductID FROM productoccasions WHERE (OccasionID = ".implode($_GET["ProductOccasionID"]," OR OccasionID = ")."))
But the Text held in $price_query is not being appended to my whereClause search. Any help would be welcome.
check the code order.
make sure that the code that creates the $price_query variable is before the code that uses it.
If it is not being included, I would suspect that it is not being created before the $WADbSearch1->whereClause .= $price_query line.
dnys04173367569
I have corrected this and have a $price_query variable that should change when a filter button is pressed.
However, any changes to the $price_query is not happening.
I believe that the orginal whereClause gets set, when the page initially loads and that will include what is initially held in the $price_query variable, but when the page is refreshed by an update to the price filter the where clause is not getting updated with the change.
Is there anyway I can force the whereClause to update and accept the change of the $price_query variable.
The variable is to be selected by a dropdown box once the page is loaded and then the customer can selected to show items based on a number of price options eg. $10 to $50 or $50 to $100.
I have tested the filter to check that $price_query does change when the filter button is selected by echoing the varaible within the same page, however the whereClause is not changeing based on the change to the variable, which leads me to believe that the whereClause is not being updated with the refresh of the page.
Any help would be greatly appreciated.
the data assist search behavior will only be applied if there is a search query string variable, make sure that the code to reload the page includes a search querystring variable:
products_Results.php?search=search
