Dynamic Plug-in Source
Thread begun 8/12/2010 8:22 pm by Brainthief | Last modified 8/17/2010 7:42 am by Ray Borduin | 1548 views | 5 replies |
Brainthief
I would like to select my plug in source from my database.
If I select my page as a data source using the dynamic plug-in, it breaks the page;
$WA_DynamicFrameworkPlugin_1 = new WA_Include("<?php echo $row_rs_sss_pages['pag_file']; ?>");
It should be home.php.
Plug-in Source - Browse for the plug-in file that you are adding.
Your plug-in source must be a PHP file.
This looks like a bug. The code should read:
$WA_DynamicFrameworkPlugin_1 = new WA_Include("" .$row_rs_sss_pages['pag_file']. "");
I'll log this issue and make sure we get a fix out in a dot release soon.
Brainthief
Thanks Ray.
Any idea how soon a dot release will be?
We'll probably wait a week or two to make sure we catch any other issues. We already have 3-4 things to fix, but so far they all seem pretty easy to handle like this one. It could change if something larger comes up, but as it stands it looks like it should be sometime right around the end of the month.
Brainthief
Also, If the page is not found, you only get;
Framwork file not found:
on a white page.
It doesn't show the "index.php"
How can I show the index.php page along with a custom error where the include should be?
The current version does not include error handling for missing files.
However if you leave a blank trigger value in the dynamic plugin, it will use that one if none of the other trigger values are found as the default, so that may work in your case.
What is the situation where the file doesn't exist? How are you setting it up so that this is a common error you need to account for? Maybe we need to add a feature to better account for this, so I'm interested in what you are looking for.
You may be able to simply delete the die(); statement causing the code to stop running and then your server 404 page would be displayed. Perhaps that is the only change we need to make. I'd like a better description of why and where you run into a page not found issue so I can give the proper advice on addressing it.
