Help with repeating table wizard
Thread begun 8/12/2010 11:03 am by iainmacdonald331081 | Last modified 8/12/2010 3:16 pm by iainmacdonald331081 | 1855 views | 3 replies |
iainmacdonald331081
As a follow up to my other thread, I'm now trying to recreate the grid layout DA created when I originally ran it to create the results page for a table of Destinations :
destinationstemp.php
(One issue there is the images extending beyond 182px wide, even though I've specified a width for the image. But that's less of a concern just now - I can add in some code to fix that that I've used in the past).
I also have the page for tour package details, which now pulls through the destinations linked to the selected tour package.
So I'm just trying to replicate the grid layout in the page above on this page :
packageDetailsTest3.php?packageID=140
I just tried using DA's Repeating Table wizard, but when I fired it up, it couldn't see any recordset to work with.
I assume its something to do with the way the code is at the top of the page - Dreamweaver doesn't seem to see it either, in its database server behaviours panel.
At the moment all of that looks like :
<?php require_once('Connections/connPackages.php'); ?>
if (!function_exists("GetSQLValueString")) {
function
GetSQLValueString($theValue$theType$theDefinedValue ""$theNotDefinedValue ""
  if (
PHP_VERSION 6) {
$theValue get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
$theValue function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
  switch (
$theType) {
    case
"text":
$theValue = ($theValue != "") ? "'" $theValue "'" "NULL";
      break;
    case
"long":
    case
"int":
$theValue = ($theValue != "") ? intval($theValue) : "NULL";
      break;
    case
"double":
$theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
      break;
    case
"date":
      break;
    case
"defined":
$theValue = ($theValue != "") ? $theDefinedValue $theNotDefinedValue;
      break;
  return
$theValue;
if (!session_id()) session_start();
$ParampackageID_WADApackages
"-1";
if (isset(
$_GET['packageID'])) {
$ParampackageID_WADApackages = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
$ParamSessionpackageID_WADApackages "-1";
if (isset(
$_SESSION['WADA_Insert_packages'])) {
$ParamSessionpackageID_WADApackages = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_packages'] : addslashes($_SESSION['WADA_Insert_packages']);
$ParampackageID2_WADApackages "-1";
if (isset(
$ParampackageID2_WADApackages = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
mysql_select_db($database_connPackages$connPackages);
$query_WADApackages sprintf("SELECT packageID, package, costperpax, duration, baselocation, category, dateadded, agerange, hotel, educational_tours, field_trips, corporate_outings, plant_visits, budget_package, rollingtours, teambuilding, description, offer FROM packages WHERE packageID = %s OR ( -1= %s AND packageID= %s)"GetSQLValueString($ParampackageID_WADApackages"int"),GetSQLValueString($ParampackageID2_WADApackages"int"),GetSQLValueString($ParamSessionpackageID_WADApackages"int"));
$WADApackages mysql_query($query_WADApackages$connPackages) or die(mysql_error());
$row_WADApackages mysql_fetch_assoc($WADApackages);
$totalRows_WADApackages mysql_num_rows($WADApackages);
$colname_WADAdestinations "1";
if (isset(
$colname_WADAdestinations = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
$query_WADAdestinations sprintf("SELECT * FROM destinations INNER JOIN (packages INNER JOIN packagedestinations ON packages.packageID = packagedestinations.packageID) ON destinations.destinationID = packagedestinations.destinationID WHERE packages.packageID = %s ORDER BY destination ASC"GetSQLValueString($colname_WADAdestinations"int"));
$WADAdestinations mysql_query($query_WADAdestinations$connPackages) or die(mysql_error());
$row_WADAdestinations mysql_fetch_assoc($WADAdestinations);
$totalRows_WADAdestinations mysql_num_rows($WADAdestinations);$colname_WADAdestinations "1";
if (isset(
Any ideas what's going on with the recordset? Or if it only exists as a query how to make it appear as a recordset?
iainmacdonald331081
OK - I redid the recordset in DW, and this time the wizard saw the recordset OK.
However, when I put the page up, its no longer displaying any destinations (I checked it was after redoing the recordset, so its only after I added the repeating table...
packageDetailsTest6.php?packageID=140
iainmacdonald331081
Getting there - I'd missed that the DA repeating table wizard didn't go through the fields to be included. As far as I can tell it just creates the shell, and needs to be built up manually with the fields, unless I've missed something.
I copied over the little table from my other page :
<table border="0" cellspacing="0" cellpadding="0">
<tr><td class="categorypic"><a href="destinationDetails.php?destinationID=<?php echo(rawurlencode($row_WADAdestinations['destinationID'])); ?>" title="Image Name"><img class="WADAResultThumb" border="0" src="../images/destinationpics/<?php echo $row_WADAdestinations["image_main"]; ?>" alt="Image Name" height="182px width="182px"/></a></td></tr>
<tr><td class="categorycell"><strong><?php echo $row_WADAdestinations["destination"]; ?></strong><br>
<?php echo $row_WADAdestinations["shortdesc"]; ?>
<p><a href="destinationDetails.php?destinationID=<?php echo(rawurlencode($row_WADAdestinations['destinationID'])); ?>" title="View"><img src="images/learnbutton1.jpg" alt="View" name="View" border="0" id="View" onMouseOver="MM_swapImage('View','','plugins/images/learnbutton2.jpg',1)" onMouseOut="MM_swapImgRestore()" /></a>
</td></tr>
</table>
But that only seems to have created a single column within the table :
Rather than the four columns here :
Have attached a current version of packageDetailsTest6.php....
iainmacdonald331081
Think I've got it now - I think I must have copied the other little table before I redid the recordset.
Have been trying it again, and it seems OK now :
packageDetailsTest9.php?packageID=140
