Problem with Latin1 / German Character
Thread begun 8/12/2010 3:59 am by victor278184 | Last modified 4/18/2011 11:09 am by Jason Byrnes | 8949 views | 3 replies |
victor278184
Hello, i have problem with Latin1/German..
when i input on HTML Editor such as:
"von Möbeln, welche unter deutscher Leitung zu 100 % in eigenen Betrieben hergestellt werden"
"Qualitätsmöbel entwickelt"
database record it as:
is this database issue ? or HTML Editor Issue ? or my Page Issue ?
please help
It is probably due to a database configuration, you should give these steps a try to see if it helps to clear things up:
1) Make sure the database could support the characters by going to mysqladmin and running the query:
alter database [enter your database name]charset=utf8;
ALTER TABLE pg1_gallery_images CONVERT TO CHARACTER SET utf8;
2) Add this line to the bottom of the connection file (/Connections/your connection file name.php) :
mysql_set_charset('utf8',$your connection file name);
michel336265
Same problem here, I have tryed to use booth tips but still I can not place ö ore any other german character.
I am using the latest version off HTML editor.
Please HELP
on your page, look for the following line of code:
$CKEditor_config["entities"] = false;
and change it to:
$CKEditor_config["entities"] = true;
