Help with inner join query
Thread begun 8/12/2010 1:34 am by iainmacdonald331081 | Last modified 8/13/2010 12:40 am by iainmacdonald331081 | 8072 views | 16 replies |
iainmacdonald331081
This is probably slightly beyond DA's functionality, but thought I'd ask here anyway, as you guys have been great with support in the past, and hopefully isn't that complicated for the experts!
Basically I have the following table structure :
table : packages
packageID
package
packageDetails
etc
table : destinations
destinationID
destination
destinationDetails
etc
table : packagedestinations
packageID
destinationID
..so nothing that complicated.
So the idea is that I can have a package details page which shows the details of the package, along any destinations linked to that package via the packagedestinations table.
So this is the last part really - to get the page to display the destinations, but I'm missing something along the way, as I can't get the destinations to display on the page here :
packageDetailsTest3.php?packageID=128
This is the PHP from the header, including my INNER JOIN query....
$ParampackageID_WADApackages
= "-1";
if (isset(
$_GET['packageID'])) {
$ParampackageID_WADApackages = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
$ParamSessionpackageID_WADApackages = "-1";
if (isset(
$_SESSION['WADA_Insert_packages'])) {
$ParamSessionpackageID_WADApackages = (get_magic_quotes_gpc()) ? $_SESSION['WADA_Insert_packages'] : addslashes($_SESSION['WADA_Insert_packages']);
$ParampackageID2_WADApackages = "-1";
if (isset(
$ParampackageID2_WADApackages = (get_magic_quotes_gpc()) ? $_GET['packageID'] : addslashes($_GET['packageID']);
mysql_select_db($database_connPackages, $connPackages);
$query_WADApackages = sprintf("SELECT packageID, package, costperpax, duration, baselocation, category, dateadded, agerange, hotel, educational_tours, field_trips, corporate_outings, plant_visits, budget_package, rollingtours, teambuilding, description, offer FROM packages WHERE packageID = %s OR ( -1= %s AND packageID= %s)", GetSQLValueString($ParampackageID_WADApackages, "int"),GetSQLValueString($ParampackageID2_WADApackages, "int"),GetSQLValueString($ParamSessionpackageID_WADApackages, "int"));
$WADApackages = mysql_query($query_WADApackages, $connPackages) or die(mysql_error());
$row_WADApackages = mysql_fetch_assoc($WADApackages);
$totalRows_WADApackages = mysql_num_rows($WADApackages);
$colname_educationalDestinations = "1";
if (isset(
$_GET['PackageID'])) {
$colname_educationalDestinations = (get_magic_quotes_gpc()) ? packageID : addslashes(packageID);
$query_educationalDestinations = sprintf("SELECT * FROM destinations INNER JOIN (packages INNER JOIN packagedestinations ON packages.packageID = packagedestinations.packageID) ON destinations.destinationID = packagedestinations.destinationID WHERE packages.packageID = %s ORDER BY destination ASC", GetSQLValueString($colname_educationalDestinations, "int"));
$educationalDestinations = mysql_query($query_educationalDestinations, $connPackages) or die(mysql_error());
$row_educationalDestinations = mysql_fetch_assoc($educationalDestinations);
$totalRows_educationalDestinations = mysql_num_rows($educationalDestinations);
And where I'm trying to display the destinations themselves, I have :
<table>
<tr>
<td>Destinations :</td>
</tr>
<?php do { ?>
<tr>
<td><?php echo $row_educationalDestinations['destination']; ?></td>
</tr>
<?php } while ($row_educationalDestinations = mysql_fetch_assoc($educationalDestinations)); ?>
</table>
If anyone could have a quick look and help me out that would be much appreciated - not sure if its my SQL at the top, or the PHP in the page, but either way it would be good to get it working.
Thanks.
CraigRBeta Tester
at first glance, the query with the inner joins looks ok.
what i would do is try 2 things..
echo the select statement to the screen, to ensure it is as it should be, and if it looks ok, try pasting it into the sql window in phpmyadmin.
if this doesn't work, try doing the same thing without any filter criteria, to ensure you are getting some rows returned.
to get your sql statement to the screen, add the line
echo $query_educationalDestinations ;
immediately after
iainmacdonald331081
OK - I can see where its going wrong, but not sure of the syntax to fix it...
echoing it generated the query :
SELECT * FROM destinations INNER JOIN (packages INNER JOIN packagedestinations ON packages.packageID = packagedestinations.packageID) ON destinations.destinationID = packagedestinations.destinationID WHERE packages.packageID = 1 ORDER BY destination ASC
So the problem is the very last part WHERE packages.packageID = 1
Which should presumably be WHERE packages.packageID = packagedestinationsID
iainmacdonald331081
OK - so I changed the obvious, to make it :
SELECT * FROM destinations INNER JOIN (packages INNER JOIN packagedestinations ON packages.packageID = packagedestinations.packageID) ON destinations.destinationID = packagedestinations.destinationID WHERE packages.packageID = packagedestinations.packageID ORDER BY destination ASC
and that returned three of the four records.
If I specify the last packageID as '128' it returns the two correct records.
But if I specify it as 137 it only returns one of the two correct records.
go back to the original query
the problem is the way the colname parmeter is set up. you have it configured as:
type: Number
default value: 1
Runtime value: $_GET['PackageID']
it should be configured as:
type: Number
default value: 1
Runtime value: $_GET['packageID']
notice the case of the 'p' in packageID.
PHP is a case sensitive language, $_GET['packageID'] is not the same as $_GET['PackageID']
If you would like a tool to help you find the correct INNER JOIN Syntax, Navicat has good visual query builder that help:
mysql_overview.html
iainmacdonald331081
Thanks jason - you're a star! Will have a look at the Navicat site too.
you're welcome.
iainmacdonald331081
OK - now I'm going to need your help in getting the destinations on this page to appear in a grid layout as they do on the original page created by DA.
I'm going to assume it'll be reasonably straightforward for you to guide me through it...
Basically, this is the original page created by DA that lists the destinations on their own :
destinationstemp.php
(One issue there is the images extending beyond 182px wide, even though I've specified a width for the image. But that's less of a concern just now - I can add in some code to fix that that I've used in the past).
So I'd like the destinations to appear in that same grid layout on the package details page here :
packageDetailsTest4.php?packageID=140
I assume its just a case of reusing some code from the destinationstemp.php page - I could have a stab at it manually, but I'd likely mess it all up....
Presumably this is the code that sets it all up in the destinationstemp.php page :
$maxRows_WADAdestinations = 20;
$pageNum_WADAdestinations = 0;
if (isset($_GET['pageNum_WADAdestinations'])) {
$pageNum_WADAdestinations = $_GET['pageNum_WADAdestinations'];
$startRow_WADAdestinations = $pageNum_WADAdestinations * $maxRows_WADAdestinations;
$query_WADAdestinations = "SELECT destinationID, destination, description, shortdesc, image_main, image_2, image_3 FROM destinations ORDER BY destination ASC";
setQueryBuilderSource($query_WADAdestinations,$WADbSearch1,false);
$query_limit_WADAdestinations = sprintf("%s LIMIT %d, %d", $query_WADAdestinations, $startRow_WADAdestinations, $maxRows_WADAdestinations);
$WADAdestinations = mysql_query($query_limit_WADAdestinations, $connPackages) or die(mysql_error());
$row_WADAdestinations = mysql_fetch_assoc($WADAdestinations);
if (isset($_GET['totalRows_WADAdestinations'])) {
$totalRows_WADAdestinations = $_GET['totalRows_WADAdestinations'];
} else {
$all_WADAdestinations = mysql_query($query_WADAdestinations);
$totalRows_WADAdestinations = mysql_num_rows($all_WADAdestinations);
$totalPages_WADAdestinations = ceil($totalRows_WADAdestinations/$maxRows_WADAdestinations)-1;
$queryString_WADAdestinations = "";
if (!empty($_SERVER['QUERY_STRING'])) {
$params = explode("&", $_SERVER['QUERY_STRING']);
$newParams = array();
foreach ($params as $param) {
if (stristr($param, "pageNum_WADAdestinations") == false &&
stristr($param, "totalRows_WADAdestinations") == false) {
array_push($newParams, $param);
if (count($newParams) != 0) {
$queryString_WADAdestinations = "&" . htmlentities(implode("&", $newParams));
$queryString_WADAdestinations = sprintf("&totalRows_WADAdestinations=%d%s", $totalRows_WADAdestinations, $queryString_WADAdestinations);
But I'm not sure how to go about reusing it with the new query in the packageDetailsTest4.php page without messing it up.
I have at least changed the recordset name to WADAdestinations which should help.
I've attached a zip of both pages - if you could advise which code to use in the new page to achieve the grid layout I'd be very grateful.
CraigRBeta Tester
Hi Iain.
I haven't looked at the code posted, but looking at the pages, i think what you want to do is to create a repeating table, (4X3 or 4x2 perhaps)
if the recordset is in place, just go to Insert->WebAssist->DataAssist->Repeating Table, and go through the wizard
iainmacdonald331081
Thanks Craig - I hadn't actually registered DA had that functionality - I had in my head it just did its thing creating all the search / results insert / update / delete pages.
So that's pretty much exactly what I'm looking for I think.
Unfortunately it wasn't that easy - I fired it up, but the wizard isn't seeing any recordset to use....
I've started a new thread on this issue rather than have it hidden away in this one, which has now been resolved.
