Trying to add charges
Thread begun 8/11/2010 10:49 am by vjc111265867 | Last modified 9/02/2010 8:33 am by Jason Byrnes | 2938 views | 5 replies |
vjc111265867
I need to add a charge to a cart if the user selects a dark color. I am setting up the charge to see if the item DarkColor is present in the cart and then using the calculation "based on column subtotal and and I am multiplying Quantity by $3.00.
No luck in getting this into the cart.
Was wondering if I am checking for the right item. There is an item in the cart called DarkColor, but should I be checking for that item or the value contained in that item? ( which could be a number of different colors)
thanks nigel
I think that it might be easier to use a calculation to add in this extra charge. You would want to have another column in your cart for a dark color type. When any of the dark colors are selected you could set this column to have a particular value to indicate so like 1.
If you had it setup like this you could alter the total price calculation to look at this column and if it is set to the value then use the price + 3 then multiply by the quantity or else just multiply the price by the quantity. It might look like this:
abs(DarkColor == 1)?(([Price] + 3) * [Quantity]):([Price] * [Quantity])
vjc111265867
Trying to get this to work with another formula
Sorry Eric for taking so long to get back, but how would I get this to work with another calculation I had to write for dealing with lowering prices based on the quantity the user selects. The formula below is working great:
(abs([Quantity]>0 && [Quantity] <= 23) * ([Price] * [Quantity])) + (abs([Quantity]>23 && [Quantity] <= 47) * ([Price]Range1 * [Quantity])) + (abs(Quantity>47 && [Quantity] <= 131) * ([Price]Range2 * [Quantity])) + (abs(Quantity>131 && [Quantity] <= 199 ) * ([Price]Range3 * [Quantity])) + (abs(Quantity>200 ) * ([Price]Range4 * [Quantity]))
I'm not sure where I plug in the calculation you gave me for dealing with dark colors?
you should just be able to add it onto the end:
(abs([Quantity]>0 && [Quantity] <= 23) * ([Price] * [Quantity])) + (abs([Quantity]>23 && [Quantity] <= 47) * ([Price]Range1 * [Quantity])) + (abs(Quantity>47 && [Quantity] <= 131) * ([Price]Range2 * [Quantity])) + (abs(Quantity>131 && [Quantity] <= 199 ) * ([Price]Range3 * [Quantity])) + (abs(Quantity>200 ) * ([Price]Range4 * [Quantity])) + (abs(DarkColor == 1)?(([Price] + 3) * [Quantity]):([Price] * [Quantity]))
vjc111265867
Price is wrong
Jason, tried plugging the DarkColor Formula at the end of the others but the price was totally off. Do I need to somehow place it into each section of the quantity formula so the the $3.00 is added to the price range that is based on quantity? If so how would I do that syntax wise?
i see, you would need to modify the conditions and use the abs function where the price is added.
for example:
should be changed to:
(abs([Quantity]>0 && [Quantity] <= 23) * ((abs(DarkColor == 1)?[Price] + 3:[Price]) * [Quantity]))
