Multiple Delete sometimes works, sometimes doesn't
Thread begun 8/10/2010 10:46 am by Thomas Hill | Last modified 8/11/2010 10:47 am by Eric Mittman | 1531 views | 1 replies |
Thomas Hill
I have created some recordsets on a page called assignment_Display.php using DataAssist Multiple Add/Delete. I have read about DataAssist currently having a bug which does not place the multiple delete functions in the right place and after moving them into the proper places, the pages works.... but only until I've added and deleted a few results. After this, the MySql table does not display the Primary ID column in a chronological format (see picture). This is my guess as to why the results are not always getting deleted.
I am very confused, since if I empty the Mysql table and start again it works fine again for a bit but then on occasion some of the results don't delete. I have included the page for you to look at. Please help....
Tom
It can be difficult to determine the cause of an issue that is not consistent. The best thing you could do to help determine what the problem is would be to try and reproduce it with some type of regularity. Could you make a backup of your db then test with the records that you have. When you are testing you should do a multiple delete then check the db to ensure that they have all been deleted. Make sure to keep track of how you are deleting the records in case there is a problem with an individual record. As soon as you can get the problem to occur with some consistency we will be able to help you look into the cause of the issue. Please post back and let us know the results that you get during this testing.
