Contact form width
Thread began 8/09/2010 5:39 am by sunsabbath76401977 | Last modified 8/11/2010 3:32 pm by Eric Mittman | 3225 views | 12 replies |
sunsabbath76401977Beta Tester
Contact form width
Hi
I've tried many different way's to alter a contact forms width to into a siteassist pro page, none of which correspond to the setting applied. Auto, doe's not work and % previews well but doe's not save into the page.
Is there an actual setting to narrow the form width?
Sabby76
With your form selected on the page you should go to 'edit design' in the property inspector. In here you should make sure that form is selected and adjust the form width setting to be like you need. If you cannot get the form to fit correctly within your page by adjusting the setting here please post back with a link to the page in question or with a copy of the page that has the form on it as well as the css and other resources that I would need to check on this locally.
Hi Eric
The recommendations did not work.
Copy attached?
Sabby76
contact_us.zip
Can you also post back with a copy of the templates directory, the css, and the form builder folder from your site in a zip archive. I will need these files in order to check this out and adjust things locally.
Also, what is the desired width that you would like the form to be?
Files
The form builder exceeded the size limit.
It will be divided a sent in the next reply.
Sabby76
Templates.zip
siteassistpro_css.zip
form builder
from file 1.1
FD_Cool_Default.zip
FD_NewFromBlank_Default.zip
form builder
from file 1.2
FD_Sharp_Default.zip
FD_Sharp_W_0FS_0.zip
form builder
from file 2.1
FC_Contact_SimpleContact.zip
FD_Cool_Default.zip
form buillder
from file 2.2
WA_ServerValidation.zip
Width, 528 pixels.
Sabby76
