Progress bar error
Thread begun 8/09/2010 5:12 am by rob75685 | Last modified 2/19/2012 6:03 am by dkriver321804 | 8593 views | 24 replies |
rob75685
Progress bar error
hi there
I keep getting errors when trying to use the Progress Bar.
The error is:
Error in initializeUI:
TypeError: pageMatch has no properties
thanks
delete the Dreamweaver cache file from the users configuration folder:
webVoodoo
progress bar error
Jumping in on this thread
I am also receiving exactly the same error as rob75685. Now, I thought the reason may be that I have 6 Digital file Pro uploaders inserted in the one form due to needing to upload multiple files, this works but I am unable to add a progress bar due to the error message. As I saw rob75685 is suffering the same error message, perhaps the progress bar will work with several Digital File Pro uploaders on one page and is in error for some other reason.
Am I getting the error message because it doesn't work with multiple uploaders?
I deleted the Dreamweaver cache, but it didn't help in this case.
Advice always greatly appreciated.
having multiple DFP behaviors on the page should cause an error with the progress bar.
login.php
rob75685
hi Jason
Deleting the cache file makes no difference...
What version of Dreamweaver are you using?
Can you send a screen shot of the extension manager showing the extensions you have installed and versions?
rob75685
Versions
hi Jason
I'm using Dreamweaver CS3
Screengrab of extensions attached
Thanks for your help
and your getting the:
error?
this error is always caused by a bad Dreamweaver cache file.
What is the path you are deleting the cache file from?
In some instances, I have seen people have to delete the cache file, then reboot the computer and delete the cache file again.
rob75685
yes that's the correct error...
my path to the config file is:
user : library : application support : adobe : dreamweaver 9 : configuration
I'll try rebooting and deleting again as you've suggested and will post back
thanks Jason
rob75685
hi Jason
Deleted the cache file, then rebooted
still the same error....
