Email will not deliver
Thread begun 8/04/2010 8:17 pm by jshafor | Last modified 8/05/2010 10:04 am by Jason Byrnes | 1663 views | 2 replies |
jshafor
An extension that has always worked flawlessly is seemingly having an issue (or I am); nonetheless, I cannot get UE4 to send a submitted form to email. After almost five hours, I concede.
I have searched everything in the forum possible and implemented any possible fix that sounded remotely close.
Here's what I've tried thus far:
- I have uninstalled and reinstalled UE3 and UE4 twice
- deleted winFile.dat
- changed the submission trigger to everything in the list
- used canned templates for the email (UE4) and created my own with "edit in DW" (UE4 and UE3)
- deleted all scripting and started a new (at least four times)
- changed: $WA_MailObject = WAUE_Definition("","25","","","",""); to $WA_MailObject = WAUE_Definition("","25","","","1","");
- called my hosting provider to get specific SMTP info (although I've used WA with this host for 18 months without a problem prior to this) (host is secure server: smtp.secureserver.net - port 25; I also tried: relay-hosting.secureserver.net)
Therefore, I just don't know what else to try and this has been five hours or trying and looking for anything and everything.
I have attached the files and appreciate your help in advance.
jshafor
UE3 coming back?
Is there a known (new) issue with UE4? I noticed some chatter about bring UE 3.07 back and notice it's pinned to the top of the Universal Email forum. Is it taking the place of UE4?
Again, I could not get it to work for this issue neither.
one issue i see that may be causing the problem is that the text fields in your form do not have a value attribute.
<input name="Name" type="text" class="formElementBg" id="Name" />
I have seen on a few servers recently where form elements are not included in the post array when filled out if there is no value attribute.
try adding value="" to the text boxes:
<input name="Name" type="text" class="formElementBg" id="Name" value="" />
The sticky post regarding UE3 is just to let UE3 owners know that an update is available.
