Format Dynamic Dropdown Output
Thread begun 8/04/2010 4:04 pm by madmatmail408476 | Last modified 8/13/2010 2:34 pm by Eric Mittman | 4985 views | 10 replies |
madmatmail408476
I have a simple parent - child dynamic drop down working but would like to format the result of the child dropdown.
It returns a list of dates but displays them in the MySQL format of "2010-10-09". How can I get it to return "Monday 9th October 2010", for instance?
The dates are also displayed in decreasing rather than ascending order - how do I amend this?
Thank you.
You can format the date in a php page with the php date function. You would need to apply this to the recordset value for the date that is referenced in the 'create dynamic array' server behavior. Here is a link to the page that explains more about the date function:
php.net/manual/en/function.date.php
To get the records to show in ascending order you will need to adjust the recordset that is used in the 'create dynamic array' server behavior. You will need to edit this recordset and set the order by, select the column, then set to ascending.
If you have any trouble with the date formatting post back withe the file in question and let me know the name of the date column and I can show you where this needs to be added.
madmatmail408476
Format Date
Hi, I was able to change the sort order no problem so thanks.
I can see what you mean about applying a date format as I have done it before in simpler cases but I cannot see where to apply it in this case.
I attach the code for the page:
(The recordset is called child and the date field is called surgery_date in veterinary_surgeon_table)
Thank you.
The line of code that you will need to edit is on line 256, here is the line:
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace($row_child["surgery_date"])."'".";\n";
You will need to apply the date formatting function around the recordset value on this line:
date("your format string", $row_child["surgery_date"])
madmatmail408476
Format Date
Hi, thanks for the reply. I am having difficulty working out what this line of code is doing so am unsure of the correct syntax to use in the line you recommended.
If I just add the date format string as below it returns all dates of 01/01/1970 (which is wrong). When I try and change the syntax I mostly get a 'Non well formed numeric value encountered' message.
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace(date('dS F Y', $row_child["surgery_date"]))."'".";\n";
Thanks.
It looks like you have added this just fine, but it is missing a crucial part that I forgot to show in my example. The problem is that the date formatting function formats a time stamp value, it will not directly re-format a date value. So you will need to add in one more part to make the current date a timestamp like this:
echo "WAJA[".$n."][".$m."][1] = "."'".WA_DD_Replace(date('dS F Y', strtotime($row_child["surgery_date"])))."'".";\n";
Sorry about that, it slipped my mind that you were working with a formated date value already. Here is a link to the php page for the strtotime function, this along with the date and mktime are very powerful tools for editing dates and times.
php.net/manual/en/function.strtotime.php
madmatmail408476
Off Topic
Thanks a lot, that works just fine now.
madmatmail408476
Follow on Question
Hi Eric. I have a follow on question. Please let me know if I should post it elsewhere but I though as you already know the code on this page...
I am trying to create a grandchild after the date drop down (which was the child). The grandchild drop down is using the same table as the child one but returning the vet name (s) for that date.
I cannot seem to get it to work.
Firstly, when I created the second Dynamic Array (for the child/grandchild relationship) the previous Dynamic Array (parent/child) disappeared from the Server Behaviours panel - I can still see it in the code but can no longer edit it using the panel because it is not there.
The situation now is that the parent (branch name) and child (date) work fine but the Select vet drop down remains blank and does not load any data - any ideas?
Thank you
It seems that you have the recordset setup correctly for this but when I view select lists and the populate list from array behaviors I see an issue. It looks like you are defaulting the child select list to get it's values from the child recordset. You should only be setting the parent select list to get it's values from the recordset, the other two lists should be populated from the populate list from array behaviors that you have.
You should apply the first populate list from array behavior on the parent list, this will populate the child list with the values you specify. Then for the grandchild list you will apply the populate list from array to the child list. So long as the id values match as a foreign key you should get the grandchild list to populate with the correct values based on the selection in the child list.
I also noticed that you had a populate list from array behavior applied to a td on the page, if you want the lists to be populated based on the selection of the previous list you should only be applying this behavior to the parent and child select lists.
madmatmail408476
Confused
Hi Eric.
I have been following your instructions. The child select list no longer get's its values from the child recordset. I have also removed the Populate List from Array that was applied to a <tr>.
I have set the rest up following the instructions and the grandchild list now comes up with a long list of blanks (instead of vets names). I have checked and the database does have relevant data - any reason why it would come up with blanks?
Your comment about Foreign Keys also puzzled me. I am using PHPMyAdmin and have never set up Foreign Keys on any of my tables and yet my first Parent - Child Dynamic Drop Downs worked fine. Are Foreign Keys something I should be setting up manually in my database for these drop downs to work?
