database table drive menu and submenus
Thread began 8/04/2010 9:19 am by andres411923 | Last modified 8/05/2010 9:13 am by Eric Mittman | 1631 views | 1 replies |
andres411923
I have a table that have all levels of menu and submenu, i have a field call parent_id, witch relational the id menu.
see this example (dababase on MYSQL)
-- TABLE STRUCTURE FOR SHOPEXAMPLE
DROP TABLE IF EXISTS `SHOPEXAMPLE`;
CREATE TABLE `SHOPEXAMPLE` (
`ID` INT(11) NOT NULL AUTO_INCREMENT,
`LABEL` VARCHAR(40) DEFAULT NULL,
`PARENT_ID` INT(11) DEFAULT NULL,
`TOOLTIP` VARCHAR(40) DEFAULT NULL,
`ORDERBY` INT(11) DEFAULT NULL,
`URL` VARCHAR(60) DEFAULT NULL,
`VISIBILITY` INT(11) DEFAULT '1',
PRIMARY KEY (`ID`)
) ENGINE=INNODB AUTO_INCREMENT=19 DEFAULT CHARSET=LATIN1;
-- RECORDS
INSERT INTO `SHOPEXAMPLE` VALUES ('1', 'WELCOME', '0', 'WELCOME TO OUR SITE', '1', 'WELCOME.PHP',
'1');
INSERT INTO `SHOPEXAMPLE` VALUES ('2', 'ABOUT US', '0', 'ABOUT US', '2', 'ABOUTUS.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('3', 'OUR TERMS', '0', 'OUR TERMS', '3', 'OURTERMS.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('4', 'OUR PRODUCTS', '0', 'OUR PRODUCTS', '4', NULL, '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('5', 'BUY NOW', '0', 'BUY NOW', '5', 'BUYNOW.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('6', 'SHOES', '4', 'SHOES', '6', NULL, '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('7', 'COATS', '4', 'COATS', '7', NULL, '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('8', 'SCARVES', '4', 'SCARVES', '8', NULL, '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('9', 'UMBRELLAS', '4', 'UMBRELLAS', '9', NULL, '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('10', 'BLACK SHOES', '6', 'BLACK SHOES', '10', 'BLACKSHOES.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('11', 'BROWN SHOES', '6', 'BROWN SHOES', '11', 'BROWNSHOES.PHP',
'1');
INSERT INTO `SHOPEXAMPLE` VALUES ('12', 'SUMMER COATS', '7', 'SUMMER COATS', '12',
'SUMMERCOATS.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('13', 'WINTER COATS', '7', 'WINTER COATS', '13', 'WINTERCOATS', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('14', 'SILK SCARVES', '8', 'SILK SCARVES', '14', 'SILKSCARVES.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('15', 'WOOL SCARVES', '8', 'WOOL SCARVES', '15',
'WOOLSCARVES.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('16', 'PATTERNED SCRAVES', '8', 'PATTERNED SCARVES', '16',
'PATTERNEDSCRAVES.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('17', 'LADIES UMBRELLAS', '9', 'LADIES UMBRELLAS', '17',
'LADIESUMBRELLAS.PHP', '1');
INSERT INTO `SHOPEXAMPLE` VALUES ('18', 'GENTS UNMBRELLAS', '9', 'GENTS UMBRELLAS', '18',
'GENTSUMBRELLAS.PHP', '1');
can i us css menu writer for create all levels menu?
thank you.
I think that you would be able to use this structure and data to make multi level menus with CSS Menu Writer. You would want to set the first level of dynamic menu items to be filtered on the parent id = 0 and set the key to the id field. Then for the sub menu you would add the set and set the filtering to parent_id and nested. I think this setup would get you the menu that you are looking for.
