Boolean Search
Thread begun 8/04/2010 7:05 am by tyler815351411 | Last modified 8/09/2010 2:05 pm by Eric Mittman | 3596 views | 5 replies |
tyler815351411
Boolean Search
I have setup a database and search function using Data Assist. All works fine but my customer wants to be able to use Boolean search in one of the fields. When I change the Column type to Number/Boolean and then try the search it seems to return everything in the database.
Please could you advise what I am doing wrong or advise how I can setup a text field to allow multiple keyword search within that field.
Example:
I want to be able to search for: ward nurse Nottingham and for only records with these keywords to show. How I have setup at the moment it only seems to have one keyword in order to show.
Kind Regards
Brian
Based on how you have described the search I don't think that a boolean search is the type that you need. Instead you should be using the keyword type search and use the includes as the comparison. The trick to get the search to only return records that contain all of the phrases is to use the logical separators for AND in the interface. The default is a comma and space together (, ). You can make it so that this is a space only and update the OR to something else. If you do this any words that are separated by a space would imply an AND in between them so that only a record where all three of these values are present in the column specified would be returned. I think this is just what you are going for.
tyler815351411
Many thanks for your response I have updated the results page and the code generated looks like this:
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["S_CV_Info"]))?$_POST["S_CV_Info"]:"") ."","AND","Includes","%20AND%20","%20OR%20","%22","%22",0);
but when i do a search it returns all records, i think i have the above code wrong.
Kind Regards
Brian
The code that is generated by the DataAssist Server behavior can be difficult to examine out of context. Please post back with a copy of the search and this results page in a zip archive so that I can take a look at them for you.
tyler815351411
Many thanks, I have attached the results and search page.
The field is CV_Info
All the other search boxes are ok.
Kind Regards
Brian
I can see that you have the search properly configured to use " AND " for the and separator and " OR " for the or separator. To see why you are getting the results you are reporting I have opened a ticket for you so that we can look into this issue further with you. To update the ticket or check on it's status please login and visit your support history.
