Validation messages are visible
Thread begun 8/03/2010 8:54 am by BruceT | Last modified 8/05/2010 3:56 pm by Jason Byrnes | 2761 views | 5 replies |
BruceT
I'm creating a contact form page for a client but the validation messages... that should only show up if the form isn't completed correctly... are all visible.
The captcha image works, the form sends the data to the right places, and it redirects to the thankyou.php page the way it should. I just need the validation error messages to go away.
I've tried putting the SpryAssets files in the root directory... leaving them in their own folder... and uploading them as part of the ContactForm folder... nothing works.
The page I'm having the issue with can be found at ~ contactus.php
your page is mising the code that attaches the spry assets:
<script src="SpryAssets/SpryValidationTextField.js" type="text/javascript"></script>
<script src="SpryAssets/SpryValidationTextarea.js" type="text/javascript"></script>
<style>
.textfieldServerError {
display:block;
margin:0px;
color:#CC3333;
border: 1px solid #CC3333;
</style>
<link href="SpryAssets/SpryValidationTextField.css" rel="stylesheet" type="text/css" />
<link href="SpryAssets/SpryValidationTextarea.css" rel="stylesheet" type="text/css" />
should be just after the title tag.
BruceT
Thank you!
It worked like a charm. Why isn't that code in the original contactus.php file?
I just downloaded the contact form solution pack files to check, and that code is just after the title tag.
BruceT
The "fix" created new issues
The fix you sent me made the error messages go away... but now the form doesn't return any results like it was before.
adding that code will only effect the form if validation is not being passed, if the spry validation passes, the form will submit.
I see you have removed the spry code from the link you provided before, can you either put it back or send a link to another page that displays the problem so I can investigate?
