Data Assist Error
Thread begun 8/03/2010 8:17 am by sinan | Last modified 8/09/2010 11:05 am by Eric Mittman | 2838 views | 4 replies |
sinan
Data Assist Error
I was using dataAssit with DW CS4 then I bough CS5 and installed and when I need dataAsssit I got error. I don't know what to do.
I am using DW CS5
DataAssit 2.0.7
Vista
Sinan
There are two things that you can try to get rid of this error. The first is to delete the cache file, here are instructions on this:
If you still have the error after doing this there might be a corruption of your configuration folder. If this is the case you will need to rename it, here are the instructions for this:
showpost.php?p=12293&postcount=2
Please post back and let us know if the issue persists after trying this.
sinan
Hi Eric
I tried first one and took almost the whole day because I have 52 extensions and 32 of them are webassist in my computer.
I will write the result in 2 days :(
sinan
Everything are OK when I reinstalled them
Glad to hear that, let us know if you have any other questions or if you run into any other issues.
