Trying to load PowerStore
Thread begun 8/02/2010 3:20 pm by robert.stock192819 | Last modified 8/03/2010 2:10 pm by Eric Mittman | 1852 views | 3 replies |
robert.stock192819
When I try to load PowerStore.
I type the following in: PowerStore300
And I get the following page?
Index of /PowerStore300
Parent Directory
AboutUs.php
Admin/
CSSFormBuilder/
CSSMenuWriter/
DynamicWebCharts/
HTMLEditor/
Images/
Scripts/
SpryAssets/
WADbSearch/
WA_CMS/
WA_DataAssist/
WA_DigitalFilePro/
WA_Globals/
WA_SecurityAssist/
WA_Universal_Email/
WA_ValidationToolkit/
WA_eCart/
careers.php
cart.php
checkout.php
checkout_failure.php
checkout_success.php
confirm.php
contactus.php
css/
faq.php
google_javascript/
images/
js/
Apache/2.2.15 (CentOS) mod_ssl/2.2.15 0.9.8l DAV/2 mod_auth_passthrough/2.1 FrontPage/5.0.2.2635 Server at www.pacificwestdigital.com Port 80
This is because you have directory browsing enabled, which is a bad idea for a web server, and also that you do not have index.php setup as a default document. You should enable index.php as one of the default documents for your site and also disable the directory browsing, this is a security risk on a live web server.
robert.stock192819
This is a brand new site and I never made any configuration changes to it - how do I disable this?
This is not a setting of PowerStore, this is a change that needs to be made on your web server. If you don't have access to these settings or need help getting them adjusted you will need to contact your host for more info.
You could continue with the setup of PowerStore by clicking on the index.php page, but these settings really should be adjusted before you make use of the store.
