What now
Thread begun 8/02/2010 1:20 pm by Remco209061 | Last modified 8/03/2010 11:44 am by Jason Byrnes | 2047 views | 3 replies |
Remco209061
What now
Unknown column 'undefinedTafelsundefined' in 'field list'
hello I want to insert a simple text in the database but it won't work. I try'd several time's and deleted the .dat file but it wont work. I'm working on a Imac OSX with CS5.
Why?
double click on the insert record server behavior, make sure the data type is set correctly for each column, then click ok.
Remco209061
see the first mail
Hello Jason
it won't work even when I delete the id field in the insert page it show up in the insert page i tryed it several time's. Is CS4 better with DA 2.0.6?
I do not see any ID field on the insert page code that you sent to me.
The error message yo are reporting is occurring because the data type for speed_pagina_naam column is not set properly in the insert record wizard.
double click the insert record server behavior, and make sure the data type is set properly for the speed_pagina_naam column, then click ok.
